help needed please
1 reply to this topic
#1 flyer
flyer
  • 250 posts
  • Local Club: smoc
Posted 25 July 2007 - 09:38 AM
ok here is the problem.my turbo engine is running very hot and no matter what i do i cant get it to come down to under 230f whats about 100oc.it as got a super 2 cor rad plus a 4 blade fan.this only started to happen when i had the carb ajusted at a show to bring down the Co leavel.so does anyone no the best way for me to setup the carb.i no where the screw is to adjust the carb just lets say if its fully in how many turns of a screw driver shoul it roughley be.
many thanks
#2 Turbo Phil
Turbo Phil
  • 2,418 posts
Posted 25 July 2007 - 04:56 PM
If the problems only arisen since the carb was adjusted it sounds to me like the engine is running very lean causing it to get hot. Screw the mixture screw in a little to richen it, drive it very carefully and get it down to a decent rolling road for a proper setup.
You certainly don't want to be driving a Turbo motor which is anywhere near lean, under any kind of boost.
Phil.
