Large ICE Install
13 replies to this topic
#1 jam2005
jam2005
  • 1,297 posts
  • Local Club: None
Posted 03 January 2005 - 02:31 PM
Currently in my mini ive got four JBL 6x9's, two JBL tweeters and a 1000w JBL sub all running off my 6-Channel JBL Amp and Pioneer head. There running at a total power of 2500 watts. If I play music loud for about 30 minutes the battery is as dead as a fart. This is because the ICE is sucking 90 Amps. I know that I need a power cap and I have heard that 1 Farad is for 1000 watts. Is this right? If so I need a 2.5 or greater Farad power cap?!?!
Please help.
Jam2005 :grin:
#2 Jordie
Jordie
  • 13,564 posts
  • Name: Jordan
Posted 03 January 2005 - 04:46 PM
Or set stereo to only work with engine running....then u wont flatten battery unless ur alternator is poor.
#3 jam2005
jam2005
  • 1,297 posts
  • Local Club: None
Posted 03 January 2005 - 06:06 PM
I do that, lol :lol: but it still flattens the battery :lol: !! The ICE is suckin' 90 Amp max and the alternator is only putting 55 Amp in the battery max. Don't really want to have to get a 100 Amp alternator :sad:
Jam2005 :grin:
#4 Alex1380
Alex1380
  • 309 posts
Posted 03 January 2005 - 08:00 PM
thats big power drain. try a stonking grate battiey biggest one you can fit in the hole. then you can buy big alernators from mini trailer i belive which is a 155amp. but u willl need to upgrade all you cabling. i run a 900watt 4 channel and a 500watt mono block with out a problem, also with out a cap, which i am thinking about.
Alex.
#5 Brawlyrox
Brawlyrox
  • 7,066 posts
  • Local Club: Cornish MOC
Posted 05 January 2005 - 09:59 AM
when u say ur running 2500w im guessing thats peak power as 2500w rms is ALOT, im pretty certain u will get away with a 1.5 farad cap as u r only running a lower rms rating.
#6 Madmax
Madmax
  • 2,638 posts
  • Local Club: Grimsby & Louth MOC
Posted 05 January 2005 - 12:51 PM
a 1 FARAD power capacitor wouldnt be enough for 2500w RMS, if its peak power youve calculated that means nothing, look for the RMS of everything and re-calculate.
as for the battery, buy a higher power battery, like a yellow top, and rig it up so that it gets charged off the alternator along with the battery that starts the engine, two power caps would be just as expensive
#7 Madmax
Madmax
  • 2,638 posts
Posted 05 January 2005 - 12:52 PM
and as alex has said, upgrade your altenator
#8 jam2005
jam2005
  • 1,297 posts
  • Local Club: None
Posted 07 January 2005 - 09:55 AM
Just bought a 1.5 Farad power cap. I'll see how that performs and hopefully I wont need to upgrade anything else :erm: . 1 more question, as always......Is this how I wire it up? :ohno: (parallel to the amp)
Cheers,
Jam2005 :grin:
#9 Alex1380
Alex1380
  • 309 posts
Posted 07 January 2005 - 10:29 AM
i thought u ran them in the power line. i will ask at work today. as i've just bought one to.
#10 Madmax
Madmax
  • 2,638 posts
Posted 07 January 2005 - 01:39 PM
it goes"
battery > cap > amp
#11 Pavel
Pavel
  • 2,451 posts
Posted 13 January 2005 - 08:56 PM
Pretty sure caps have to be wired in parallel :lol:
Also a) there is no way that your system is putting out 2500w rms through 6x9's and a sub (tweeters use up negligible power)
and B) If it WAS, it would be around 200 amps, not 90 (how did you do your calculations? :ohno: )
That cap should help you with your bass, nothing else... If your battery or electronics seem to die quickly, replace alt as been said above with a powerful one, but they aint cheap!
#12 jam2005
jam2005
  • 1,297 posts
  • Local Club: None
Posted 13 January 2005 - 10:36 PM
I thought that you always wired the power cap up parallel to the amp. That way it acts as a small second battery for the ICE :erm: .
p.s. Pavel the install is 2500w peak power, not RMS. I wish :ohno:
Cheers,
Jam2005 :grin:
#13 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 17 January 2005 - 01:16 AM
whats the indervidual rms ratings? by the sounds of it a cap wont make any difference to the longertivity of your battery, a cap wont produce any more power for you and is discharged in seconds, it is only momentary peaks of power demanded by the amp. I would give an extra 10 mins at the most to ur batteries life just fior the few seconds it will give ur alternator a chance to add a little more power!
to me by the sounds of it you dont have a very good battery or alternator! if i was you i would run at least a calcium and as big as u can fit in the battery box!
a better way of sorting ur problem than getting a cap is to get a yellow top, thesebattierais are sillily powerfull and really depednign on how long u leave ur system on full wack will last u alot longer and give ur alternater a buetter chance of recharging
#14 jam2005
jam2005
  • 1,297 posts
  • Local Club: None
Posted 17 January 2005 - 01:30 PM
Hopefully the power cap will be here early this week. Going to halfords tonight so hopefully I can get a calcium battery aswell. When heard theres a 20% sale on, on all batteries. So if anyone else wants a battery nows the time to get one.
With the calcium battery and 1.2 farad power cap I rekon (hope :lol: ) that its going to cure the problem. If not 100 amp alternator, yellow top battery and a new wiring loom will have to be ordered :ohno: . Ouuuuchhhhhhh!! :nugget: .
Cheers,
Jam2005 :grin:
