Question about fusebox and under-bonnet ground location...
Posted 30 July 2007 - 02:45 AM
I know that on the 4-fuse box, the first (top) and third fuse are connected to the ignition switch, but which side of the box should I connect my switched wire to, in order to properly complete my circuit? I ASSUME (dangerous word there, I know) that the right side of the box (as you're looking at it standing in front of the car - in other words the PASSENGER side on a RHD car) is the switched side, seeing as how there's a brown, unfused wire leading to the #2 fuse - I know that plain brown is generally the color code for unfused direct-to-battery positive.
Is this correct? Also, if I have an extra terminal on the box, above the wire that's clipped there, can I also clip to that free terminal? They look like they both run from the fused connection, but it's difficult to be 100% sure.
Last, can anyone recommend a convenient ground connection near the fuse box? I've located my relay a few inches form the box, but the relay needs a ground connection for the trigger voltage to function properly. There are some wires clipped to the screw securing the fuse box to the firewall - is this a suitable ground location? There's nothing about this being a ground in my Haynes book...
Thanks a million as always!
Posted 30 July 2007 - 05:36 AM
Posted 30 July 2007 - 08:45 AM
If the wires are black 'n screwed to the body they're earths.
Posted 30 July 2007 - 12:28 PM
If it's just a relay it won't add much load to the circuit but it does beg the question what are the spots tapped in to?
Exactly - this is just for the TRIGGER VOLTAGE for the relay... the main power for the spots is independently fused and runs from the direct-to-battery lead on the starter solenoid (based on numerous tips from here). You must never, never, EVER connect anything electrical in your car without a fuse!!
FYI in case anyone doesn't know - a relay switches open or closed when a small amount of DC current is sent across it, completing a SECOND, independent circuit (containing much more current). In this way, the actual switch in the cabin only has to handle a tiny amount of current compared to the much more robust circuit powering the actual lamps. If I use a switched power supply for the trigger voltage (usually less than .5A), then there's no way that I can leave the driving lamps on because the moment I take out the key the trigger voltage that's holding the relay closed will disappear, breaking that connection.
I just want to hook to the correct side of the fuse box so that I get a bit more protection in the form of that glass fuse. With such a small amount of current present in the wire for the trugger voltage I probably don't NEED to fuse that connection, but I'm obsessive that way. And hey, nothing;s ever caught fire in my car, or even came close to smoldering, so I guess anal-retentiveness pays off (at least when it comes to wiring).
Posted 30 July 2007 - 07:00 PM
I hear from another forum, that the right side of the fuse box (assuming you're standing in front of the car - the passenger side on a RHD vehicle) gets the protection of the fuse. Just an FYI... I'll use the screw securing the fuse box to the sheet metal firewall as the trigger voltage ground. Thanks!
