Cellulose Drying Time
16 replies to this topic
#1 _Ad_
_Ad_
  • 482 posts
  • Local Club: Minis 'n' Oatcakes
Posted 30 July 2007 - 07:12 PM
Just spraying a Suzuki GS750 for my dad with black cellulose and was just wondering what is the recommended length of time I should leave it to dry for before coloursanding and polishing?? I'd estimate I put about 12 coats on all together, bare metal respray.
Cheers! :-
#2 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 30 July 2007 - 07:15 PM
Leave it until you can apply pressure with the end your finger nail and it doesn't mark it at all. That's how I tell if paint is dry enough to polish.
#3 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 30 July 2007 - 07:19 PM
give it a day or so.
relax - admire - feel proud in your achievement and dont rush and c*ck it up due to impatience - like what I did.
have you used a lacquer over the top?
#4 _Ad_
_Ad_
  • 482 posts
Sounds good enough to me lol!
Cheers mate
#5 _Ad_
_Ad_
  • 482 posts
Posted 30 July 2007 - 07:21 PM
I've sprayed a few bikes before but this one is going to be up to on the road concours standard so I need get it spot on really! :-
Just wanted see what other peoples opinions were on it :angry:
No laquer its just a 1k gloss top coat.
#6 _Ad_
_Ad_
  • 482 posts
Posted 30 July 2007 - 07:27 PM
Heres a side panel I sprayed about a week ago and cut back today, hoping I can get the tank the same!!
#7 _Ad_
_Ad_
  • 482 posts
Posted 30 July 2007 - 07:37 PM
Oh another quick question... I had a problem before on another bike where the celly paint would stay fine for a few days after spraying then develop indents and ruts, crazing really in the surface, what would cause that? All the prep was fine, but I didn't bare metal any of that one so could it of been what was underneath the primer causing it?? Really puzzled me!
Edited by _Ad_, 30 July 2007 - 07:39 PM.
#8 roofless
roofless
    Sticker Pimp
  • 7,215 posts
Posted 30 July 2007 - 07:53 PM
panel beater peter will know more on this front but I would hazard a guess at reactions between paint types. or a problem with the thinners you are using perhaps?
All I know is I've cocked up more paint jobs than a little due to rushing and I was told to be far more patient - its paid off and by using lower pressures, better paint, more thinners and longer drying times I've had some pretty good results recently.
A decent gun helps as well - ditched my Kestrel second hand gun for a new Sata and its made hell of a difference in final finish.
#9 roofless
roofless
    Sticker Pimp
  • 7,215 posts
Posted 30 July 2007 - 07:54 PM
looking good - you should be well proud of that.
#10 _Ad_
_Ad_
  • 482 posts
Posted 30 July 2007 - 08:21 PM
Thats what I was thinking to be honest but theres no reason why they should've caused it really as they were the most expensive top gloss thinners I could get locally and everything was mixed accurately. Could've been a faulty batch I suppose.
#11 Woody
Woody
    Ring Runner 2005
  • 1,763 posts
Posted 31 July 2007 - 07:54 AM
This sound like the pait you used reacted with the paint that was allready on the tank , the thinners in the paint attacks what is under , soaking in as the paint dries breaking down what is under it , take it back to bare metal or use an isolator coat like barcoat
#12 _Ad_
_Ad_
  • 482 posts
Posted 31 July 2007 - 10:48 AM
That would make sense really, definitely bare metalling it anyway when I get round to it :proud:
#13 R1minimagic
R1minimagic
  • 4,660 posts
Posted 31 July 2007 - 06:57 PM
I've had this before and it is really annoying. The primer coat is absolutely perfect but it gets some small crazing when you put the top coat on. I switched to a different primer and it was fine so i dont use that primer anymore.
#14 _Ad_
_Ad_
  • 482 posts
Posted 31 July 2007 - 08:52 PM
Yeah that could be another reason.
Anyway I've got this one all done now!! :proud:
Not come up bad seen as though they're it's original 30 year old panels!
Edited by _Ad_, 31 July 2007 - 08:52 PM.
#15 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 31 July 2007 - 08:53 PM
yeah it's a reaction between the two kinds of paints. The top coat kind of "melts" the old paint underneat and it has a bit of an argument. Always best to strip totally and re-prime or as woody says, use barcoat, but even that is always a bit dodgy if you ask me!
