a split pin through the clutch casing
Posted 01 August 2007 - 08:31 PM
Posted 01 August 2007 - 08:39 PM
so the fact you have oil coming out the hole, suggests that the oil seal (or indeed, though less likely, the bushes in the primary gear) needs attention.
no idea on the noise - though overheating doesnt do engines any good...
hth,
Dave
Posted 01 August 2007 - 08:54 PM
cheers dave just checked on my other mini and your brilliantly corret split pin is present how do i go about replacing the seal??? do i need to remove the crank case??the splitpin is supposed to be there - it keeps the hole clear so that if the clutch oil seal blows oil drains out of it..
hth,
Dave
Posted 01 August 2007 - 09:08 PM
need to get the flywheel out, old oil seal out (there is another thread around detailing that), then new seal back in... maybe worth a new clutch whilst you are there as oil could have contaminated it...
full details in the Haynes...
Posted 01 August 2007 - 09:24 PM
Posted 02 August 2007 - 07:58 AM
Can be done in the car:
If your doing it in the car I suggest you borrow a primary gear pulling tool, turns a ball ache job into a 2min simple job.
Posted 02 August 2007 - 02:04 PM
In either case the first course of action is to remove the flywheel. Once that's done however before you replace the seal thoroughly inspect the clutch case to make sure there isn't a breach into the sump or transfer gear chest anywhere.
Also if heat soak is as much of a problem as it sounds then the block could be pretty well sludged up or the water pump or rad on it's way out. How hot is it running before it boils?
Posted 02 August 2007 - 03:08 PM
Posted 06 August 2007 - 05:44 PM
If the seal or bushes were at fault then oil should only be coming out of the clutch drain hole while the engine is running. If you really mean it the way it sounds in the first post and the oil is pouring straight out as you pour it in it could point to much more serious problems. I would be suspecting a puncture through the drop gear housing, probably at the idler gear bearing as the 3rd motion bearing is mostly outside the clutch case I seem to remember and if that were punched through oil would flow directly onto the ground without entering the clutch case.
Dan i read you post and my heart dropped only had the car less than 12 hours and your saying the clutch housing has a hole punched in it... well guess what ... you were F*(KING right can't believe it removed the clutch and casing to find a dirty 10mm hole just left of the split pin. in amongst oil and dirty there were the remains for 5 bearings not round anylonger but funky squares and oblongs as well as a lump of metal that was once attached to the clutch housing.... not just a £19 clutch seal for minispars any longer a whole new gear box..... oooo joy.... any way i think im going to start my own diary on here called THE HIGHS AND LOWS OF MINI DRIVING.. so keep your eyes pealed.... forget to say whilst the car was up on the rack i had a pep at the rear subframe only to find big rusty holes through it... MOT FAILURE ONCE AGAIN...
Edited by Rusty The Clubman, 06 August 2007 - 05:45 PM.
Posted 06 August 2007 - 06:29 PM
Edited by icklemini, 06 August 2007 - 06:30 PM.
