plastic windows
$way
, Aug 02 2007 04:36 PM
10 replies to this topic
Posted 02 August 2007 - 04:36 PM
i think this is the best place to ask as most people with z cars have plastic windows...
basically i want fixed rear windows. i am going to make them from plastic because its cheaper but i only have opening rears and need a template or something to use to mark them on the plastic
what have people used for a template? is a glass window the only option?
also what plastic should you use?
cheers
J
cheers
J
Posted 02 August 2007 - 09:19 PM
duno what plastic to use cz if you have a z-car mini u should but air scoops in the rear windows but.... ye just use the other window as a template....
Posted 03 August 2007 - 11:23 AM
Probably best to use poly carbonate rather than perspex as it is a lot more scratch resistant. You should be able to do the windows for £50-60 I think.
I got a big sheet of polycarbonate for making the top part of my engine bulkhead but havent used it yet.
Posted 03 August 2007 - 02:03 PM
polycarbonate it is then.
nobody has a template then? ill have to source a window from somewhere...
Posted 03 August 2007 - 06:45 PM
hi mate,
you could make a template from hardboard...
Posted 05 August 2007 - 04:21 PM
trace the opening onto cardboard then add the amount of the lip at the opening, aprox. 1/4", 3/8", or 1/2", what ever is needed. then just screw them onto car...
Posted 05 August 2007 - 06:48 PM
never thought of doing it like that, i was going to use a rubber seal. straight onto the car would be easier but how water tight would it be?
J
J
Posted 14 August 2007 - 02:26 PM
Sorry to hi jack but how do you attach the windows to the body? is it just a case of screwing/riveting them?
Posted 14 August 2007 - 06:08 PM
Yes, add sealer around edge and screw them on. use screws so you can remove at some time later for what ever..
Posted 14 August 2007 - 06:32 PM
I rekon i would look miles better with the rubber seal...
