So how do you pro's remove all the oil and mud from under the car and also the glue and stuff from the carpets inside before you paint them??
Removing the dirt from your car before painting
1275MIN
, Aug 04 2007 04:22 PM
4 replies to this topic
Posted 04 August 2007 - 04:22 PM
Posted 04 August 2007 - 08:04 PM
Scrapers, Chisels, Heat guns, Celly thinners... and lots of time and patience
Posted 05 August 2007 - 10:44 AM
Wire cup on a grinder works too,
Posted 05 August 2007 - 10:42 PM
except on wet underseal or mud as it just clogs them straight away and there a bar steward to clean
as above i find scrapers and chisels good
my favourite new stuff though is 'Pro clean' you hose the surface down, spray on the pro clean leave it for 5 minutes and then hose it all off,
its non harmfull is non accidic so doesnt kill the alloys etc only problem i have got with it is im running out of the stuff and i cant find some more of it anywhere
wayne
Posted 06 August 2007 - 11:27 AM
if you can get access to it a either a steam cleaner - (good for getting an adhesive stuff off) or a pressure washer, just make sure you dry the whole car properly after or the shell you've just got red to paint will simply rot again ( then again if the budget will stretch you could get the whole thing acid dipped but sometimes that only reveals more problems)
