hi peeps. got a puzler for you. got my sub and bits and bobs all wired in but when i crank it up load the sub amp will keep switching off on the large base bits even with the engine running, i doubt its cableing because its all 8gage wire and all fuesed nicly. any tips?
amp cut outs
Alex1380
, Jan 13 2005 08:43 PM
7 replies to this topic
Posted 13 January 2005 - 08:43 PM
Posted 14 January 2005 - 07:54 PM
amp overheating? my m8s does this on long deep bass drops and we cant work out wether it is overheating or the amp isnt powerful enough. amp is 600w rms and so is the sub
Posted 15 January 2005 - 10:25 PM
i dout its over heating becasue the amp would go in to protection mod and its not its is just switching off
i am worried it mite be the amps isn't powerfull enough but it won't be easy to work out if that is the problem
Posted 16 January 2005 - 08:14 AM
its jsut an idea but maybe there is a loose conection in the amp, so when you get a big bassy bit the conection is lost
Posted 16 January 2005 - 06:38 PM
you can get this same problem in factory OEM fitted head units at high volume on larger speakers
as there isnt enough power running to the amplifier to power the speakers it can make the amp trip and cut out for only say a second or two, i see it alot, especially in vauxhalls
Posted 17 January 2005 - 01:00 AM
or halfords audio boards
Posted 17 January 2005 - 01:01 AM
lol yeh thats true
Posted 20 January 2005 - 07:32 PM
i found the amp is going in to protechtion. so im not sure if it is pre-amp voltage or if its the amp isn't powerful enough.
