Nitrous kit
Posted 12 August 2007 - 04:46 PM
i want about a 25-35 bhp shot but dont know which kit to get...
Wizards of nos, NX, NOS i dunno.
any advice welcome.
Posted 12 August 2007 - 04:59 PM
Posted 12 August 2007 - 05:19 PM
try big gav
Damn, my suggestion foiled!
Posted 12 August 2007 - 06:06 PM
Posted 12 August 2007 - 06:14 PM
May be better making your own kit up by buying parts cheap on ebay.
I got a 25lb bottle (full) for £70 the basic kit was £100 which included fuel t piece, bottle connector, nitrous hoses, fuel hoses solenoids, micro switch, missile switch injector and several jets.
Then i got a Schnitz controller which pulses the sollenoids to bring the gas (and extra fuel) on slowly so as not to break wheels loose of the tarmac with the sudden increase of power..... this alows me to run 100 HP jet set up and start at as low as 10 per cent power and increase as needed (it will ramp up over a period of time up to whatever max power i need.)
Posted 12 August 2007 - 08:48 PM
also how long does the bottle last?
Posted 12 August 2007 - 08:49 PM
Posted 12 August 2007 - 08:51 PM
Posted 12 August 2007 - 08:57 PM
do Minis run better on the "wet" (wizards) or "dry" (others) system?
wet.
dry nitrous is only any good in very small doses where a car has EFI and a lamda so that it can increase its own fuel supply to try and make an ideal mixture... wet kits induce extra fuel and liquid nitrous in the correct proportions and give much bigger gains.
Posted 12 August 2007 - 08:58 PM
Posted 12 August 2007 - 09:05 PM
thanks for the info.
Posted 12 August 2007 - 09:08 PM
A bloke called John Williamson who used to design and build dyno's (rolling roads) and drag race motorbikes... basically, he got hold of a nitrous kit to see how it all worked but was able to develop his own kits and do real time tweaks as he had is own private dyno at his disposal. He has done for Nitrous what Vizard did for the A-series and tested pretty much every kind of engine to destruction.
He was paralysed in an accident and now designes special wheelchairs that can climb stairs.
NITROUS LINK
there are links to all his stuff on this page so happy reading.
Posted 12 August 2007 - 09:26 PM
how likely are the engines to fail when using nos?
If you my dad's mate it can throw the rod from your new Chevrolet, clean into the tarmac of a Nevada road. Meaning a call to the wife to pick you up.
Posted 12 August 2007 - 09:32 PM
Posted 12 August 2007 - 10:38 PM
and seenwizards are the best from what i've been told.
