could do with a new alternator im pretty sure mines knacked and its only the standard one anyway,
i need the cheapest one to be a straight swap or easy conversion and the most powerfull.
it needs to run:
all the standard stuff
headunit
2 amps
1 sub
6 speakers
8 light tubes
Klaxon horn
Does a rover metro one fit because i think some of thouse are 100A!
Alternator
insamoufonyx
, Aug 14 2007 07:25 PM
3 replies to this topic
Posted 14 August 2007 - 07:25 PM
Posted 14 August 2007 - 07:47 PM
I used a 75amp Nissan bluebird one I think. Cost me £30 new. ... well reconded.
Posted 17 September 2007 - 03:24 PM
It could be helpful if anyone has experimented with other makes and madels of alternators to mention details of them (part #s perhaps)
I'm currently looking at replacing mine for a higher output but don't know which one to get.
It's hard to find mini parts in Venezuela, so direct fit suggestions will be greatly appreciated.
Posted 17 September 2007 - 09:13 PM
i recondition them, to be honest a lot of the problems is down to bad connections rather than anything else..
you dont need to bang on the biggest one that'll fit - that puts excessive load on the engine pully (that is only held together with rubber!)
