Exhaust Blowing, Where's My Leak
Mr W
, Aug 18 2007 06:47 PM
13 replies to this topic
Posted 18 August 2007 - 06:47 PM
Hi people, me again with yet another problem.
My exhaust is blowing quite badly and have noticed that when I put my foot down i get a bit of hicupping in 3rd and 4th.
Are the 2 related, the engine is firing fine.
How can I determine where the air is getting in, the manifold gasket was changed a couple of weeks ago, although when I look at the gasket between the carb and the manifold there appears to be a bit of perishing.
Could this be my problem??
Posted 18 August 2007 - 06:50 PM
put ya hand over end of exhaust and you will hear where its coming out lol
Posted 18 August 2007 - 06:53 PM
careful, it may be hot
Posted 18 August 2007 - 06:54 PM
well yeh lol.. do it when its been turned off for a few hours
Posted 18 August 2007 - 07:06 PM
Tried this, there are no obvious noises coming from under the bonnet. There is however a very strong smell of exhaust fumes???
Posted 18 August 2007 - 07:18 PM
where from the front?? can you smell it in the car.. (with doors and everything shut)
Posted 18 August 2007 - 07:27 PM
No smell in the car, but yeah strong under the bonnet.
Posted 18 August 2007 - 07:31 PM
only place really then is like manifold or downpipe somwhere round there :s..
Posted 18 August 2007 - 07:32 PM
Carb gasket do it?
Posted 18 August 2007 - 07:34 PM
dont know mate.. carnt you see it coming out anywhere when you start it.. best time to see will be on a cold morning to see it..
Posted 18 August 2007 - 07:36 PM
No obvious signs of a leak. As I said it looks a bit rotten where the carb meets the manifold. I would imagine this is my best bet.
I'll pick up some firegum amd see if it helps, if it does i'll be replacing that pronto
Posted 18 August 2007 - 07:37 PM
take the spark plugs out, pour a bit of redex down each plug hole. put the plugs back in, leave it for a while. then fire it up, and put your hand over the end of the exhaust. the smoke will come out of wherever theres a leak in the exhaust system.
dont worry about the excess smoke, thats just cleaned your cylinder head and pistons out a bit!
Posted 18 August 2007 - 07:45 PM
i might give that ago lol
Posted 18 August 2007 - 07:48 PM
useful ifyou have annoying neighbours.
