Like the title says it's time to worry! MOT next month and I know it's going to fail! I have created a list:
None of the electrics work (no wipers, no washers, no lights etc)
Both wheels rock (when the car is jacked up or on the floor you can grab the top of the wheel and rock it) Guessing Wheel bearings??
It runs on
Needs new front passenger side indicator unit.
On top of this there are other problems:
Needs a new needle ready for the stage 3 head, halogen conversion needs doing and new suspension.
Here is the shopping list from minisport....
Bulb Holder - Front Indicator/Flasher
Part number: 37H5528
£4.64 £4.64 Remove Item
Crystal Headlamps
Part number: SPDYL-3314C
£29.07 £29.07 Remove Item
4-way - Fuse box - Screw Terminal
Part number: LMA711
£5.98 £5.98 Remove Item
Front Subframe Rear Mount
Part number: 21A2599
£3.11 £6.22 Remove Item
Wheel Bearing Kits
Part number: GHK1140
Type: Front - Taper Roller type
£11.80 £23.60 Remove Item
Sports Suspension Kit - GAZ & Adjusta Ride
Part number: SUSKIT2
£179.68 £179.68 Remove Item
Carburettor Springs - HS - SU
Part number: AUC4387
Colours: Red - 998cc Stage 1 Kit
£3.96 £3.96 Remove Item
Carburettor Needle - Spring type
Part number: CUD1005
Option: AAF - 998cc Stage 1 + Head
£7.76 £7.76 Remove Item
nett £260.91
shipping £8.51
tax £47.15
Total: £316.57
Does this sound right or overly expensive and not worth the hastle??
Time To Worry
TheKing777
, Aug 19 2007 02:05 PM
3 replies to this topic
Posted 19 August 2007 - 02:05 PM
Posted 19 August 2007 - 02:10 PM
have fun doing all off this
price seems about right
Posted 19 August 2007 - 02:14 PM
Big list of bits there.
and since we don't know what the rest of the car is like we can hardly say if it'd be money well spent.
I'd do the minimum before the test only what's cheap and an obvious fail. Once it's failed you'll know what needs doing and if it's worth spending the cash.
Posted 19 August 2007 - 02:20 PM
I agree with Ethel.
