Mini One Steering Problem
3 replies to this topic
#1 Rick_Line
Rick_Line
    Starting My Mini Up
  • 1 posts
Posted 19 August 2007 - 05:30 PM
Can anybody give me a clue why my car makes a noise after parking it?
Its a mini one and has less than 25K on the clock.
It developes a noise from the steering column when turning in a tight spot for example when when parking it.
I would rather understand what the problem is before I let the mechanics rip the thing to bits.
cheers
Richard
Edited by Rick_Line, 19 August 2007 - 05:33 PM.
#2 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 19 August 2007 - 05:31 PM
Sounds like a worn rack.
#3 mab01uk
mab01uk
  • 11,817 posts
Posted 19 August 2007 - 05:52 PM
Rick this forum is for classic Minis, some of us also own the new MINI but you need to go to Mini2.com. Here is a link their with possible answer to your steering problem which I have also had on my MINI One which may help:-
http://www.mini2.com...ing-column.html
#4 redhotmini
redhotmini
  • 1,607 posts
Posted 19 August 2007 - 05:55 PM
rack hitting bump stops, which are probably non existent if you yank on the wheel when on full lock. had this problem with one of the work vans, it turned out when the driver reversed, lookedover his shoulder and pulled the wheel round a tad more. wrecked 3 sets of bump stops in 60,000 miles.
the other 2 vans are fine, because everyone else can park them without using full lock.
