Minifins Issue
Posted 21 August 2007 - 02:08 PM
I can see any way around this short of machining out the inner lip in a lathe.
Has anyone else encountered this problem? Is there a solution?
Posted 21 August 2007 - 02:21 PM
I bought a nice shiny set of Minifins from Minisport a while back and have today gone to put them on only for the inner lip to come afoul of the friction material on the brake shoes.
These should fit straight on, machining them out will remove all the lining rendering them useless.
Have you backed off the shoe adjuster on the backplate reducing the shoes to their smallest diameter?
Posted 21 August 2007 - 02:24 PM
Posted 21 August 2007 - 02:55 PM
EDIT: And the handbrake isn't on/is slackened off?
Posted 21 August 2007 - 04:14 PM
And i tryed backing off the shoe adjustment screw/bolt but its seized
I think ill be off to Somerford tomorow to get a new backplate assembly.
Posted 21 August 2007 - 10:24 PM
Handbrake isnt even attached jammy
Very expensive way of sorting the problem out buying new assemblies.
Remove the shoes & springs holding them on, take out the wedged adjusting blocks & apply heat to the housing the adjusting screw fits into & it should undo, once out give the screw a good clean or replace with a new one (£3) make sure you apply plenty of copper ease when re assembling to stop it happening in the future.
With the screw wound fully out you will then be able to fit the minifins on.
Posted 22 August 2007 - 01:13 PM
Posted 22 August 2007 - 03:46 PM
Im going to have to buy a special spanner
Posted 22 August 2007 - 04:44 PM
Yes a brake adjusting spanner will work a treat - unless the peg is buggered up now after the mole-grip experience...Im going to have to buy a special spanner
Posted 22 August 2007 - 06:46 PM
Plenty of heat & the use of mole grips should be enough to shift it, apply plenty of WD40 & leave it over night if your not having a go now then tomorrow try again with the heat.
Remember to remove the adjusting screw it needs to come towards you as they are fitted from the front!
