Compression Ratio
Posted 23 August 2007 - 03:36 AM
I would like to have a 10,5:1 to 11:1 CR
I have been reading "Tunning the A-Series Engine" 3ยบ Edition and I need some information....(page 222-223)
Bore: 70.625mm or 70.61mm STD ?? I've seen a lot of different numbers
Stroke: 81.28mm or 81.33 ??
Head Gasket: GEG300---3.8cc
Piston Dish: 8.4cc
Cilinder Head: 21.4cc
(*)Ring Land Volume: I don't have any idea
(**)Volume above piston and below block deck: the same, no idea!!!
I need this information (*) (**) to set properly the CR
Posted 23 August 2007 - 07:20 AM
I'll have a look..
Posted 23 August 2007 - 07:55 AM
Posted 24 August 2007 - 12:09 AM
There's a thread somewhere which details how to discover the above, and also a spread sheet for working it all out, but as a 21251 is a 8.8 LC piston, unless the block has been decked or the chamber volumes reduced (by skimming) then expect your compression ratio to be iro 9:1
I'll have a look..
do you have the link??
yes, I think is too low
Posted 24 August 2007 - 12:22 AM
Posted 24 August 2007 - 01:08 AM
Is it assembled? The most reliable way would be to measure it.
yes, but I have the head off
Posted 24 August 2007 - 06:26 AM
Posted 24 August 2007 - 09:29 AM
Use a graduated pipette to fill a combustion chamber with paraffin or similar. Put a piston to tdc and do the same to a cylinder - use a known quantity of plasticine or grease that doen't dissolve in what your chosen fluid is to seal the gap above the rings. A piece of perspex with a hole in is handy and easier than getting things totally level. Just add the quoted figure for the head gasket
Posted 24 August 2007 - 12:02 PM
Would it be the one you put in the FAQ's?Sorry could not find the thread, well within 5 minutes of looking, but it's there somewhere...
www.afracing.com/cr.xls
Alan...
Posted 24 August 2007 - 02:44 PM
Posted 24 August 2007 - 03:13 PM
Posted 24 August 2007 - 03:19 PM
Posted 24 August 2007 - 03:20 PM
