And Another Thing.... Anything To Bare In Mind When Plumbing An Mg Metro 1275 In My Mini
Posted 23 August 2007 - 04:01 PM
Once again cheers people......
Posted 23 August 2007 - 04:30 PM
Work out the clutch before you fit it are they both verto, non verto, or one of each?
Engine mounts & stabiliser
Heater / manifold plumbing, bypass hose?
Ignition wiring you'll want to use the Metty dizzy is it electronic what was the mini?
Starter motor will need to be off the same engine as the clutch if one's pre engaged and the other inertia.
Speedo pinion?
Posted 23 August 2007 - 05:57 PM
Posted 23 August 2007 - 08:23 PM
I'm putting a metro 1275 unit in my 1985 city e, with quite a few mods too... is yours being modified along the way?
Yeh mines going in an 1988 city e, i've got a stage 3 head so yeh will be slightly mod'ed
Posted 23 August 2007 - 09:33 PM
The mg metro has a oil cooler fitted and a longer oil filter as it goes 12000 miles between oil changes but the standard mini filter fits just change the oil after 6000 miles, but I still had to cut a nick out of the front subframe because of the oil cooler sandwich which put a extra 2 inchs on the length.
Please remember this was 22 years ago 1985 how time flies
thanks turny
Posted 24 August 2007 - 07:59 AM
I put a mg metro engine in a mini 22 years ago if I remember correctly I only thing that was a problem was clearance of the oil filter.
thanks turny
Thats a year before I was born, but I'll believe you hehe, ok sounds likes it on now.
Posted 24 August 2007 - 11:17 AM
Edit: didn't read the turny's post in too much detail, he's obviously answered the oil filter housing thing
Edited by schneill, 24 August 2007 - 11:18 AM.
