I've got a Minus that I've been building over the summer, and I've finally got to the point where I've got the engine in, wired up, and I'm trying to start it! This is where the fun begins.
The engine is from a Metro, that I've put a Ultralite steel flywheel on, along with steel backplate and orange diaphragm. I was told the engine ran sweetly when it was removed, oil had been put down the bores to keep it from rusting, and indeed there was no lip on the bore when the head was removed. Clutch cover was changed for a pre-verto, and starter was changed to pre-engaged along with the solenoid wired in on the inner wing. The wiring loom that was in there originally was found to be rubbish, so replaced with a loom from B reg Mini (84-85). I've wired in a permanent feed from 12V fusebox - fuse 1. Anyway, I'm sure the ignition side of things isn't causing the problem, as the problem persists even with the coil unconnected.
The problem is that on the starter the engine is turning over VERY slowly. And one or two points in each rotation it almost stops, as if its binding. They seem to be the same two points on each rotation, which makes me think it might be mechanical rather than a problem with the starting circuit.
Something I should point out now is that because of the fibreglass body, the engine earth lead is connected to the subframe, on the same bolt that the earth cable that runs straight through the car to the battery is on. The starter solenoid is also earthed via a cable to this bolt, however this earth cable isn't any sort of special wire, does it need to carry a lot of current?
When the spark plugs are in, as I say it spins over far too slowly, with the plugs out it still doesn't spin over as quickly as it should. With spark plugs out I connected jump leads directly to the starter motor transfer case bolt and one to the +ve terminal. It did spin over much quicker, but still not sure if it was quick enough to start it.
Is the engine binding a serious problem, a result of it being stood for a while maybe? Would this be enough to put too much load on the starter?
I have been told that sometimes bolts through the transfer case can catch the flywheel and cause it to slow, but I've looked for this and it isn't the case.
Any help with this. I've put in a great deal of money and time into this and I'm all but stuck now!
I bought a new multimeter a couple of days ago, can anyone go through the steps and readings I should take so I know that nothing is wrong with the wiring side of things?
Edited by MinusMan, 23 August 2007 - 10:30 PM.
