Light Flywheel
24 replies to this topic
#1 ginigwunkle
ginigwunkle
  • 2,018 posts
  • Local Club: sheffield mini club
Posted 26 August 2007 - 08:51 PM
ok everyone says the flywheel is worth lightening, so im goin for it,
minispares ultralight fly,
what else should i change at the same time? i have nearly new clutch plate and diaphragm also gettin performance release bearing...
is the lighter backplate worth 90 PUNDS!?
new straps bolts etc.....?
Edited by ginigwunkle, 26 August 2007 - 08:52 PM.
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 26 August 2007 - 09:04 PM
You don't want to go ULTRA light on a road car.
Well not unless you want to restart at every set of lights you come to.
#3 ginigwunkle
ginigwunkle
  • 2,018 posts
Posted 26 August 2007 - 09:06 PM
is that rite i just heard itd be a lumpy idle.....
#4 Big_Adam
Big_Adam
  • 7,435 posts
Posted 26 August 2007 - 10:03 PM
Well, an ultra light is okay on a race engine with a high idle. Do a search the topics popped up a few times.
#5 m1n1
m1n1
  • 737 posts
  • Local Club: I'm unsociable
Posted 26 August 2007 - 10:11 PM
that expensive backplate is lovely, I have one! It is noticabley lighter than the standard type from qh they sell. if you have the money go for it, with a normal lightened flywheel.
[attachment=38442:DSCF3495.JPG]
#6 ginigwunkle
ginigwunkle
  • 2,018 posts
Posted 26 August 2007 - 10:25 PM
ok so ive gone for the fly and backplate how do i know how much theyve taken off the horns etc in order too space correctly to avoid slipping????
#7 m1n1
m1n1
  • 737 posts
Posted 26 August 2007 - 10:42 PM
the minispares flywheel comes with 3 metal spacers, which may or may not be the correct thickness. You will need to check they are the correct height, and adding washers if needed to pack it out between the horn and drive strap. Quite easy.. actually it may even come with instructions if you're lucky!!!!
#8 ginigwunkle
ginigwunkle
  • 2,018 posts
Posted 26 August 2007 - 10:48 PM
oooooooh instructions theres a rare thing! lol
who knows lady luck maybe with me.......
you shall be hearing from me if shes on holiday!
#9 blacktulip
blacktulip
  • 6,221 posts
Posted 26 August 2007 - 11:22 PM
im running the MED stage 1 clutch kit and it doesnt run rough or stall. well worth the spend IMO.
#10 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 27 August 2007 - 08:15 AM
How can I tell if my flywheel is lightened without having another one to compare it to? I was told it was by the guy I bough it all from but most of what he told me turned out to be lies so I am just wondering!...
#11 ginigwunkle
ginigwunkle
  • 2,018 posts
Posted 27 August 2007 - 02:51 PM
weigh it.....? lol
med kit looks gooooood! may order that when they opens!
Edited by ginigwunkle, 27 August 2007 - 03:01 PM.
#12 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 27 August 2007 - 04:28 PM
dude yours can't be setup properly or something if it stalls at lights because of the flywheel....
i'm running and ultralight flywheel and backplate and mine idles perfectly at 900rpm, as does everyone else i know with one. (apart from one mate who runs a 300 degree scatter cam so his idles at 1100)
#13 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 27 August 2007 - 05:42 PM
Been over this, not going over it again.
It all depends on the spec of engine.
#14 Big_Adam
Big_Adam
  • 7,435 posts
Posted 27 August 2007 - 07:19 PM
Really........crappit.
Well then, learned something new.
Ignore previous comments.
#15 ginigwunkle
ginigwunkle
  • 2,018 posts
Posted 30 August 2007 - 11:09 AM
yeah spoke to med and they sa never ahd the problem with stalling...got tobe imbalanced incorrectly spaced or something not quite rite.
ordered the st1 kit from them should arrive today!!!>
