Hi all,
Can the standard adjustable front upright joints be replaced with the Mini Metro front upright joints? If so is there anything to be aware of in regards of modding the fitment?
Mini Metro Front Upright Joints In Place Of Standard
Az_RacingGreen
, Aug 27 2007 07:56 AM
5 replies to this topic
Posted 27 August 2007 - 07:56 AM
Posted 28 August 2007 - 07:58 PM
Bump
Posted 28 August 2007 - 08:58 PM
Here's one fitted to the bottom of a mini hub, not my car.
Posted 29 August 2007 - 08:17 AM
That's great, thanks
Posted 29 August 2007 - 09:15 AM
What are 'front upright joints'?
Do you mean ball joints, swivel hubs ?
Rumour has it the taper of the metro ball joint pins changed so only the earliest ones fit mini wishbones.
Posted 29 August 2007 - 11:03 AM
As can be seen on that photo - they are not a direct fit. The Mini ball joint is a female thread whereas the Metro is a male thread - Miglias use an adapter that is 'basically' a threaded tube. However they have taken into account the canges this makes to the suspension geometry - not so easy on a road car!
