Hi can anyone please help, I have just fit a new gearbox and rod selector to my cooper sportspack and I can only get 1st and 3rd gears . The gear stick feels as if it only goes as far back as neutral so I can not select 2nd , 3rd or reversve.
Please tell me the whole engine doesn`t have to come back out
Bri
Gear Selection Problem
miniscoot123
, Aug 27 2007 06:54 PM
3 replies to this topic
Posted 27 August 2007 - 06:54 PM
Posted 27 August 2007 - 07:18 PM
Doubt you'll have to remove the box.
Who built the gearbox, have you had the diff covers off?
Have a look at the rod linkage it could just be fouling.
If it isn't disconnect it anyway and you'll be able to see if you can select a gear with a rod through the roll pin hole and check movement of the gear lever to decide where the fault is.
Posted 01 September 2007 - 06:30 PM
Posted 02 September 2007 - 06:35 AM
Probably Rover... MPI's are notorious for gearbox problems...
