Firstly i have an oil cooler, is there any particular way its meant to flow, like what pipe goes to what part of the oil ways? Also i want some 10 inch wellers i remember hearing they fit over 8.4inch disk setups is this true? As i want to go onto 10's as cheaply as possible, without putting drums on the front.
Couple Questions....
CAU998
, Aug 28 2007 01:20 PM
5 replies to this topic
Posted 28 August 2007 - 01:20 PM
Posted 28 August 2007 - 01:45 PM
Yea they wellers will fit with a 1/2 + spacer, + you have to grind some of the caliper off...
Posted 28 August 2007 - 02:29 PM
i think the cooler has to flow in one end as the oil will pass down the cores rather than up the cores. might be wrong.
Posted 29 August 2007 - 08:12 AM
Argh damn thought it was an easier swap over than that. May have to have a little tinker then. And thanks ill try to find out cause im clueless to what direction they flow in etc.
Posted 29 August 2007 - 08:54 AM
dont think oil cooler has a way around... both input/outputs r on the top
Posted 29 August 2007 - 09:15 AM
nah thats not always the case... we have an oil cooler with one input at top and output at the bottom
