K-series Gt
Posted 28 August 2007 - 05:16 PM
more l8r
Posted 28 August 2007 - 05:19 PM
Posted 28 August 2007 - 05:27 PM
Thanks for the kind remarks boocool what subby are you using?
its an home made (part work) (i used to restore classic cars a few years ago)
so bought a 1/2 finished frame from fat hedgehog but the welding was tat so i ground it all off and re-welded at work. I had to make some mods to it though as he had built it up without starter/alternator in place think he was going to fit them with sky hooks lol.
also the tie rods where a mile out so ive spent 50 hours on it to sort it all out, at least it's now looking quite good
Edited by lastmanshooting, 28 August 2007 - 05:28 PM.
Posted 29 August 2007 - 06:31 PM
Posted 29 August 2007 - 07:42 PM
keeping the injection for fuel economy more than anything else its got 52m/m throttle body on so should breath oklooks good! nice subby! good luck with the wiring! u keeping all the std runnign gear for injection or u goin carbs and ignition controller?
its an early gti engine with ally manifold and no pas system to worry about lol
thanks for the interest what are othr people putting in was offered a 1600 honda vtec today needs a new dizzy though
Posted 22 October 2007 - 06:36 PM
hi there peeps got the k-seies running oooorrrraaahhh, BUT think im havin a fueling problem as it will only run for a few seconds then stops and will only start after the pump is purged.keeping the injection for fuel economy more than anything else its got 52m/m throttle body on so should breath oklooks good! nice subby! good luck with the wiring! u keeping all the std runnign gear for injection or u goin carbs and ignition controller?
it will only re-start after the key is turned off then back on any ideas peeps
Posted 23 October 2007 - 01:27 AM
Posted 23 October 2007 - 06:08 AM
Posted 23 October 2007 - 07:07 AM
Posted 23 October 2007 - 08:30 AM
got the keys coded properly??
common problem on the k-series engines.
check 16vminiforum.com
by the way... loving the build.. any chance you could gimme a pm to talk about a few ideas i have?
Posted 23 October 2007 - 08:34 PM
hi miniboo no inertia switch is connected yet as i was just trying it come to the conclusion that its the ecu turning th injectors off, so its been sent away today to get it to free run let you know monday how it wenthave you got the fuel cut off switch connected? and if you have have you checked it is ok?
Posted 23 October 2007 - 08:35 PM
matt you have pmusing standard ecu?
Posted 23 October 2007 - 08:37 PM
cheers frankie its going great the only thing is the clutch now and some f/glassing on the clubby frontlooks great nice subby
good luck with the rest
Posted 23 October 2007 - 09:47 PM
it was bungle i sprayed some fuel into the throttle body and it keeps running so i checked the injector pulse with noids and sure enough they turned offsounds like a fuel problem
Edited by lastmanshooting, 23 October 2007 - 09:48 PM.
Posted 23 October 2007 - 10:06 PM
