Hi,
Noticed that the minsters brakes seem to function very well....too well.
She will lock up very easily. I am runing on 5x12 minilites with good yokos.
I thought about uprating the brakes but doesn't that simply mean that she will lock up even more?
I supose disks on the rear will help, Is this an easy conversion for a sort of mechanically mided person?
Ta
James
Can't wait to get some copper grease to stop that teeth pulling sqeel. Do I slop it oll over the back and sides of the pad only?
Enthusiastic Braking.......
jamesheath
, Aug 29 2007 11:49 AM
6 replies to this topic
Posted 29 August 2007 - 11:49 AM
Posted 29 August 2007 - 11:52 AM
Discs are pointless on the back of a Mini. It already has too much braking power under its bum. Which end locks up?
Posted 29 August 2007 - 12:43 PM
Apols, meant to say, its the front that locks up under pretty moderate braking at lowish speeds (40 and above I guess). it is probably just the way of the mini.
Intrested to see how folks ease the problem though.
Ta Ethel once again (you stalking me?)
J
Posted 29 August 2007 - 01:22 PM
when was the last time you changed ur pads?
When i changed mine and set them up i could lock the back...
(hey simon! yes i am on TMF at work )
Posted 29 August 2007 - 01:26 PM
Dont push the pedal so hard ?
Posted 29 August 2007 - 03:34 PM
Sounds like brake balance to me is it fitted with an adjuster?
Posted 29 August 2007 - 04:19 PM
Where might i find the adjuster? I assume it is the front rear balance?
James
