Replacing Roof Lining
Posted 29 August 2007 - 09:08 PM
Replacing the roof lining on the car next weekend and just wondering what other stuff I may need to complete the job. I'm picking up the material from Huddersfield Minis at the Stafford show and I also picked up a new set of window rubbers from MITP but just realised they didn't give me the chrome locking strips?
Will I need to get glue or anything else while I am at the show on Sunday??
Any help / advise greatly appreciated.
Posted 29 August 2007 - 09:30 PM
In regards to fitting my best advise is to use a good quality contact adhesive like evo stik. Use the spray stuff, its much easier to apply then and is very quick to set.
Obviously all the glass and seals have to be out .
Start from the back of the car and work your way forwards swapping sides to keep it all in line.Spray one area then whilst that area is going tacky fit an area of the lining you've previously sprayed (if that makes sense?)
Use bulldog clips (the more the better, i found 40-50 is great) to hold the glue till it goes off.
Most importantly, don't rush it!
Posted 29 August 2007 - 09:51 PM
Posted 30 August 2007 - 08:20 AM
Thanks again for your help.
Posted 30 August 2007 - 08:43 AM
As a quick word of advice id say, if it doesn't look tip top as soon as youve done it leave it a few days. The heat in the car will tighten up the material and it will look alot tighter. I found this with mine and after a week or so it looks proffesional.
Posted 30 August 2007 - 08:49 AM
Posted 30 August 2007 - 09:18 AM
I would still use as many buldog clips as you can get your hands on.
Posted 30 August 2007 - 10:31 AM
Posted 30 August 2007 - 10:43 AM
does it help to heat the lining with a hairdryer before you fully stick both sides, so that it stretches tight once it cools? Well thats what we did with the lotus and it seemed to work a bit!
Yep, as long as your careful!
Posted 30 August 2007 - 11:25 AM
Posted 30 August 2007 - 12:03 PM
great advice- i have just recieved my new headlining from mini spares so im listening very carefully!
but a few more questions- what does a bulldog lip look like?
and i have a 6 pt roll cage in situ- will the headlining fit with out me taking the cage out? (please noooo!)
Posted 30 August 2007 - 12:20 PM
http://cgi.ebay.co.u...1QQcmdZViewItem
great tip with the seals!
it worked for me so i thought i'd pass it on....
Posted 30 August 2007 - 01:39 PM
Is there a tool for putting the window rubbers back in??? Do I need the chrome insert around the rear and front windows????
Great amount of advice thank you all its really helping me prepare for whats comming up!!
Posted 30 August 2007 - 03:54 PM
my tip is not to cut anything off untill you have finished putting it in place, then trim it
^^ Very good tip and with the bulldog/seals trick, that should set you in good stead. Some people in the local club can do headlinings at utterly rediculous speeds using this technique.
