Brake Test Button
18 replies to this topic
#1 mike.
mike.
  • 6,176 posts
Posted 30 August 2007 - 02:53 PM
As far as im aware the brake test button is not important/doesn't do much plus the previous owner said its not connected in my car.
So i'm thinking of taking that out and relocating my fog light switch there. Then i can get rid of the little switch panel where the foglight was for a cleaner look to the interior.
Good idea? I don't need the brake test switch do i?
#2 alexcrosse
alexcrosse
  • 3,786 posts
Posted 30 August 2007 - 02:54 PM
*alex puts head in hands after clicking on the search button to make sure its definatly working*
#3 mike.
mike.
  • 6,176 posts
Posted 30 August 2007 - 03:00 PM
I tryed that i swear! But the search function on this forum isn't that great and its pretty sensitive. So searching for brake test switch brings up like 30 pages of topics - most of them about braking systems. Its pretty useless really unless your just searhing for something in general, rather than something specific like this.
#4 schneill
schneill
  • 127 posts
  • Local Club: Tyred And Exhausted
Posted 30 August 2007 - 03:02 PM
Just leave it there, and make it work. Then buy one of the chrome five switch panels and relocate the fog swith to the now spare hole that you've aquired.
Schneill
#5 Matt
Matt
  • 4,703 posts
  • Local Club: The mini forum - i live here
do away with it....
#6 mike.
mike.
  • 6,176 posts
Posted 30 August 2007 - 03:04 PM
Schneill
See i would have done that, but i'v just bought a 4 switch bezel before i thought about it.
#7 Mephiston
Mephiston
  • 386 posts
  • Local Club: London and Surrey
Posted 30 August 2007 - 03:10 PM
only get rid of it if you make it a point to check your brake fluid regularily
#8 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
  • Local Club: www.lcmoc.com
Posted 30 August 2007 - 03:39 PM
Schneill
Actually I'm considering moving to a 5-switch panel now you've got the idea into my head, would this one be suitable?
MINISPARES LINK
Bearing in mind I've got a '85 Mayfair and it's got the standard 4-switch setup at the minute.
Only trouble is if I move my fog light switch there, I'll have another switch spare (immobiliser fob). I suppose this could be concealed somewhere but it has a red flashing light for a reason.
#9 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
Posted 30 August 2007 - 03:40 PM
I thought you'd need it for the MOT? Why is it not connected, has/have the tag/s broken off the fluid filler cap? That's why mine isnt working :dontgetit:
#10 schneill
schneill
  • 127 posts
Posted 30 August 2007 - 03:46 PM
Yeah, that 5 switch panel will do the job, the chrome ones look good as well. A believe you can get walnut ones as well. They're good, but with all the switches with wires on the back it becomes a tight squeeze. Worth it because you get rid of the "after thought fog" light switch panel
#11 Matt
Matt
  • 4,703 posts
Posted 30 August 2007 - 03:47 PM
dont think its required for the mot.. mine wasnt...
#12 schneill
schneill
  • 127 posts
Posted 30 August 2007 - 03:48 PM
This falls back to the whole "if its not there, they can't test it" surely?
#13 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
Posted 30 August 2007 - 03:53 PM
Don't know really, if it's a funny tester they might have a list of what cars of a certain year must have as standard. Anyway I'll look into a chrome one, walnut wouldn't suit my car because it's all black leatherette effect stuff inside. Chrome would though :dontgetit: see if I can find one somewhere.
#14 schneill
schneill
  • 127 posts
Posted 30 August 2007 - 03:54 PM
Try huddersfield mini spares. think thats where i got mine from. Sorry for post hijack. :dontgetit:
#15 1984mini25
1984mini25
  • 8,785 posts
Posted 30 August 2007 - 03:55 PM
Or the way I like to look at it, why did Austin/rover etc, bother putting it there if it didn’t need to be there and save the time and more importantly money on fitting it to every mini.
It IS NEEDED as it tells you are low on brake fluid, which is normal done on newer car via a little light on built into the clocks/dials, so if you wish to remove it, you need to replace it with an equivalent.
And just because one mot tester passes it for not working/missing doesn’t mean every one will.
And for anyone wondering the 4 switch and 5 switch plates are the same size and are a direct replacement size wise.
Edited by 1984mini25, 30 August 2007 - 03:56 PM.
