Brake Test Button
18 replies to this topic
#16 Matt
Matt
  • 4,703 posts
  • Local Club: The mini forum - i live here
Posted 30 August 2007 - 03:58 PM
well when questioning the mot fella.. he said it doesnt need to work when pressed.. but should light up when level is low...
but they have no way of testing that surely?
#17 mini_morley
mini_morley
  • 674 posts
Posted 30 August 2007 - 04:05 PM
Shorely (sp) if it doesnt work when pressed, then it wont work when the fluid level is low?
Mine doesnt work, because one of the terminals had corroded off, and it just passed an MOT...
#18 1984mini25
1984mini25
  • 8,785 posts
If you remove the cap with the two wires still connected or to test the circuit press down the button in the centre of the master cylinder cap, both of which you should see that the brake test switch lights up.
#19 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
  • Local Club: www.lcmoc.com
Posted 30 August 2007 - 04:08 PM
Yeah they can just take out the brake fluid which should make the float go down inside the cap which in turn should activate the light.
In either case I'd strongly advise to keep it and repair it. What if you're on a long journey and you're losing brake fluid, how will you be able to tell? You could end up wrapped around a tree. I know it sounds harsh but it is there for a reason like 1984mini25 said.
