Hif44
17 replies to this topic
#1 FailleARQ
FailleARQ
  • 160 posts
  • Local Club: www.clubminimania.cl
Posted 31 August 2007 - 02:35 PM
Hi all.
I have recently buy a hif44 carb from ebay UK (Im from Chile)
and this one have a small cilinder with two electric connections
what are that for??? I have read something about an electronic choke
this carb will work in a mini???
The carb have no serial number but it says JZX2007
I added a picture
Edited by FailleARQ, 31 August 2007 - 02:58 PM.
#2 Mephiston
Mephiston
  • 386 posts
  • Local Club: London and Surrey
Posted 31 August 2007 - 03:40 PM
well i dont know for certain, but thats where the choke assembly would go usually so i have to assume its an electronic chock, problem with that is, if you dont have an electronic ignition it wont work on your mini....
#3 FailleARQ
FailleARQ
  • 160 posts
Posted 31 August 2007 - 03:53 PM
it have a normal choke in the other side
#4 Mephiston
Mephiston
  • 386 posts
Posted 31 August 2007 - 03:57 PM
hmm....really - show us a pic if you can - im intreged
#5 FailleARQ
FailleARQ
  • 160 posts
Posted 31 August 2007 - 04:07 PM
this is the other side
#6 FailleARQ
FailleARQ
  • 160 posts
Posted 31 August 2007 - 05:24 PM
anybody?
#7 Ethel
  • 25,996 posts
Posted 31 August 2007 - 05:35 PM
Looks like it may have been an Hif electronic carb:
The choke will have had a stepper motor controlling it but it looks like it has been removed. I don't see any reason why you can't use it with a cable choke with a suitable attachment.
The bit with the electrical connections is a fuel cut off valve, the electronic control unit will have operated it when the car was on over run to save fuel. You can just ignore it or get inventive to squeeze out a little bit more fuel economy.
#8 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 31 August 2007 - 05:37 PM
Don't you mean an automatic choke perhaps?
I believe that the Austin Maestro (for example) had an auto choke and a HIF44 carb?
#9 Ethel
  • 25,996 posts
Posted 31 August 2007 - 06:00 PM
Essentially the Hif E is an auto choke, I suppose the electronic tag made it sound more grand in an attempt not to make the Maestro look so poor compared to fuel injected rivals. I suppose they were justified as it also did the overrun fuel cut off and is more sophisticated than other auto chokes.
#10 flamejob
flamejob
  • 297 posts
  • Local Club: TMF!
Posted 31 August 2007 - 07:10 PM
FailleARQ: Me sorprende que puedas enternos, nuestra ortografia es muy mala. :D
#11 FailleARQ
FailleARQ
  • 160 posts
Posted 01 September 2007 - 01:39 AM
I have unscrew the electronic "thing" and take this picture...
The thing cutoff the pass from hole Nº1 to hole Nº2 which go to the the top pipe (thats the overflow I think)
I can see the needle inside hole Nº1
Please sorry for the bad english, it is not my first language, Im chilean
Edited by FailleARQ, 01 September 2007 - 01:40 AM.
#12 FailleARQ
FailleARQ
  • 160 posts
Posted 01 September 2007 - 01:43 AM
This is another HIF44 Ive got...
It has the same electronic device and...
What it is for the part marked on the picture???
#13 FailleARQ
FailleARQ
  • 160 posts
Posted 01 September 2007 - 06:17 PM
bump
#14 FailleARQ
FailleARQ
  • 160 posts
Posted 02 September 2007 - 06:12 PM
anyone knows??
#15 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 02 September 2007 - 08:08 PM
no idea, but i found an HIF44 in my garage the other day thats got some weird things on it. i'll put a pic up soon if thats helps lol.
it seems different to your two failleARQ...
Edited by minidan, 02 September 2007 - 08:24 PM.
