will any mini subframe fit in a clubman, front +rear
Silly Question
bennett
, Aug 31 2007 06:09 PM
5 replies to this topic
Posted 31 August 2007 - 06:09 PM
Posted 31 August 2007 - 06:15 PM
Clubman is no different to a saloon, the pre / post 76 issue still applies.
Posted 02 September 2007 - 02:53 AM
does it make a difference if the subframe is off a 93 cooper inj
Posted 02 September 2007 - 03:00 AM
1 more thing, can i use the loom from any mk mini or does it have to be from a clubman
Posted 02 September 2007 - 09:22 AM
The only loom difference on a clubman I can think of would the be Headlamp arrangements
Posted 02 September 2007 - 12:49 PM
An injection subframe would fit if the clubby has the same post 76 big bolt mountings, the engine might sit a little further forwards.
A later loom would fit but would need a few modifications:
A late carburettor model with the same instruments and column swithes as the clubman would be the easiest option. Sorting the sidelights would be easy enough but you may have to adapt the starter/solenoid and ignition connections too and, of course, use the later fusebox and any relays.
