Any ideas what this could be it has recently had a stage one and been fully roling roaded, and was working fine last nite.
Posted 06 September 2007 - 08:03 AM
Posted 06 September 2007 - 08:36 AM
Posted 06 September 2007 - 08:56 AM
check under the bonnet for any hoses or pipes that may have popped off the carb like a breather or split etc (could be running very lean if a pipe has come off) have a general prod and play with things plug leads etc make sure stuff is connected and secure check for a fuel leak? get someone to operate the choke in the car and watch the linkage on the carb make sure it returns fully if the choke is stuck on it may cause running problems...
Posted 06 September 2007 - 09:30 AM
Posted 06 September 2007 - 10:26 AM
head gasket perhaps mine blew across 2 & 3 cylinders and it woudl still drive but would rev right up and sounded a bit rough
Posted 06 September 2007 - 10:38 AM
How would i check if thats blown?
Posted 06 September 2007 - 10:44 AM
Compression test is a simple and easy way of showing problems with combustion chamber sealing (eg head gasket probs).
Though I'd start with the checking of the hoses/choke etc. as above....
Will it rev over 2500-3000 with no load? Or is it just lacking power?
Posted 06 September 2007 - 10:51 AM
I had same problem and tryed loads of stuuff but turned out to be vac pipe between distributor and carbJust got to work and my mini decided it wudnt go over 2500 - 3000 revs, which was pretty scary when i tryed to pull out at an island quickly
Posted 06 September 2007 - 12:18 PM
Posted 06 September 2007 - 01:08 PM
It idles OK? Revs OK without load?
By all means check the things mentioned above. However, if this is a car with carbs, I'd accelerate the car under load until it "tops out" then IMMEDIATELY switch off the engine and push the clutch in. Bring the car to a stop (still in neutral) and pop off the carb's float bowl to check the fuel level.
Running into a wall like that can also indicate a fuel delivery problem caused by any number of things... pump problems, blocked filter(s), plugged inlet screen (some carbs), partially plugged jet tube....
Edited by fairshepherd, 06 September 2007 - 01:11 PM.
Posted 06 September 2007 - 01:12 PM
that wa the problem if it is off or split it doesnt advance the distributor under loadIt idles OK? Revs OK without load?
right sounds like somthing else to try, had a look about in my lunch break. Cudnt see anything apart from the carb elbow had worked its way lose and so carb is sucking air directly from the filter. Could this be part / all of the problem?
Posted 06 September 2007 - 01:43 PM
Posted 06 September 2007 - 02:10 PM
Right so if i just fix that should all go back to normal, mite just get a cone filter les hassel. What type is it for a 1991 998cc is it a hs4?
Posted 06 September 2007 - 05:59 PM
By carb elbow you mean the 90 degree casting in between the carb and the plastic filter housing? Do you mean the engine wasn't drawing all it's air from the filter? I doubt very much that would be the cause of your problem.
I think miniman thought you meant the vac pipe between the carb and distributor. To check this pull the dizzy cap off, then pull the hose off at the carb and suck on it. If you don't see the vac advance functioning inside the dizzy (it will be obvious), or get a mouthful of air then this could be your problem.
It could be many things, fuel, ignition or compression related. Do you think you will be able to get it home?.
If/when you do the ignition cut method as dklawson posted above, have a look at the plugs too as they could give an indication of how the engine was running when it started going awry...
Edited by fairshepherd, 06 September 2007 - 06:02 PM.
Posted 06 September 2007 - 06:48 PM
