Spot Welding Vs Mig.
Posted 07 September 2007 - 07:32 PM
I am shortly going to replace my front panel. In order to do so I intend to hire a spot welder. I also need to repair the iner wings where the front panel meets them. Now, my skills with a MIG are not great, so I am wondering if I were to apply repair patches to the inner wings with a continual seam of overlapping spot welds - will that be good enough for the MOT man? Not sure if i could even manouver the spot welder into position yet , but with no front panel I thought that i might?
What are yer thoughts - and remember there's a fine line between genius and insanity!!!
Matt
Posted 07 September 2007 - 07:35 PM
Posted 07 September 2007 - 07:44 PM
http://www.mig-weldi...k/plug-weld.htm
Posted 07 September 2007 - 07:58 PM
Posted 07 September 2007 - 09:08 PM
Evenin'
Matt
Repair patches as far as I know have to be seam welded (where they are structural/within 12 inches of suspension mountings). If you are replacing a panel then you can spot weld it on.
I have always pot/pool welded with a mig when putting on new panels - rather than spot welding, but you do need to be acurate and make sure that the weld goes through and melts into the lower panel.
Posted 07 September 2007 - 11:04 PM
Posted 08 September 2007 - 12:24 AM
If the joint was originally spot welded it can be refitted by spot or plug welding, if there were no joins ie part of a panel is being fitted or a patch then the joint should be seam welded ie a continuous weld ( not stitched or a line of spot welds)
You could make a continuous weld of spots that'd be stronger than a butted seam weld, of course that'd be impossible if you couldn't access both sides of the panel.
Posted 08 September 2007 - 09:43 PM
a continuous weld of spots would not be allowed on a join which was not an original spot welded joint
as if it was a line of spot welds there would be gaps between each weld.
Posted 08 September 2007 - 10:13 PM
same strength if u practice
Posted 08 September 2007 - 10:51 PM
only need access to 1 pannel for plugs too
plug welds would only be allowed on a previously spot welded joint,
a spot wld is a resistance welded joint using electrodes
and a plug weld is a fusion welded joint utilising a drilled / punched hole
and a metal filler ie mig / gas weld.
Posted 08 September 2007 - 11:35 PM
Petrol tanks are put together with continuous spots. It may well be true tha MoT testers won't accept anything other than a continuous seam weld but they're not the strongest means of joining steel - otherwise cut 'n shut cars would be readily accepted as road worthy
Posted 08 September 2007 - 11:44 PM
Posted 09 September 2007 - 07:10 PM
Matt
