Advice Needed
Posted 09 September 2007 - 09:47 PM
I stirred the paint tonight and it seemed really thick (1 will my gun cope its a devilbliss gravity 1.8 (2what pressure should i have (3 will the
gun be ok for the top coat 2k aswell solid colour (only have the one gun) (4 what pressure for the topcoat THANKS IN ADVANCE. J.D.
Posted 10 September 2007 - 09:04 AM
Posted 10 September 2007 - 09:42 AM
and as above.. you have the pressure as high or as low as you want.. as long as the gun isnt spitting the paint.. then its down to personal preference.
Posted 10 September 2007 - 09:57 AM
a devilbis gun should be able to spray the primer providing it is mixed to the right ratio.I always spray around 60psi and upwards depending on the paint used.I use Mipa 2 pack and found it to be really good for maximum coverage and price per litreHi experts my questions are as follows Iam spraying my mini in my friends garage tomorrow night. My primer is HS primer 2k it says4:1:1
Posted 10 September 2007 - 04:35 PM
Posted 10 September 2007 - 08:03 PM
1> Yes that gun is perfect for primer, mix the primer 4:1 with about 10% thinners and it'll be great.
2> 200 psi any higher it'll be rough feeling, any less you won't get a nice even coat.
3> A 1.8 setup is too big for a solid, it'll bang it on too fast and you'll probably get lots of runs! you want a 1.3/1.4
4> Same pressure as the primer.
