Can Anyone Modify My Badge To Look Like This
Elisha-The-Cooper
, Sep 10 2007 12:36 PM
1 reply to this topic
Posted 10 September 2007 - 12:36 PM
IVE THE BADGE HERE BUT I CAN SEND, ALSO I HAVE A WINGS BADGE TO CUT UP.
ALL I NEED IS SOMEBODY TO PRINT OFF THE PICTURE AND LAMINATE IT OF SOMETHING TO GET THE SHINEY EFFECT.
HERE IS THE HI DEF PIC YOU CAN USE
PLEASE.
BEN X
Posted 14 September 2007 - 09:10 PM
sorry just seen this post if you are still trying to do this then you might be able to do a little trick i found out some years ago,
1 print off the picture onto photo glossy paper
2 cut out picture to size
3 get some clear wood varnish and give the photo four or five coats making sure the first coat is very thin,
but make sure it absorbs into the paper,
warning the varnish might cause the ink to run so try a couple of different types,
you can use the varnish for modelling in the little metal tins i think they are made by hemmel
4 once it has dried for a couple of days place it into a bowl of water and slowly and i mean slowy rub the paper off of the back
once the paper is gone you should be left with the image on the varnish ready for transplant onto your badge.
i hope this helps and it would be good to see a photo of the finished item if you do it.
