Can Someone Tell Me What This Is
jonny-b
, Sep 17 2007 03:44 PM
9 replies to this topic
Posted 17 September 2007 - 03:44 PM
What is this and what does it do
im Quite new to mini mechanics and couldnt find it in the haynes
Thanks Guys
Thanks Guys
Posted 17 September 2007 - 03:47 PM
Heater Tap. Turns on flow of coolant to heater in car, should have a cable running to the arm that sticks out of the front.
Edited by GraemeC, 17 September 2007 - 03:48 PM.
Posted 17 September 2007 - 03:49 PM
Heater valve opens & closes with cable from dash to allow hot water to heater unit
the more it opens, the hotter the air from your vents will be
Posted 17 September 2007 - 03:51 PM
Unless it's like mine & hot as son as you start pull it out
Posted 17 September 2007 - 03:56 PM
This explains why my buddies heater do not work seems to have seized.
That great guys i really appreciate that.
on all the minis I have owned i have never used the second knob - the heater has always managed to get to full tilt without it.
Posted 17 September 2007 - 04:05 PM
Is it just me, or do the vents (at least the ones in the dash) not actually blow out any warm air (unless it's a warm day!) regardless of what the heater is doing? I didn't think they were connected...?
Posted 17 September 2007 - 04:19 PM
Thats because they are fresh air vents and not part of the heater
Posted 17 September 2007 - 05:33 PM
Minis up to '88 push for heat, Minis '88 on pull for heat. If your cars were all pre 88 the heater is set to full with the cable pushed right in.
