is that very hard? I am an amateur after all lol NO ITS FAIRLY EASY . WOULD HAVE DONE IT FOR U BUT ON A DIFFERNT ISLAND ,, ANYWAY POP TO YOUR LOCAL GARAGE AND ASK THEM TO FIT AN ELECTRONIC IGNITION FOR U WILL ONLY COST A FEW POUNDS.hi id say up :thumbsupgrade the ignition to electronic if u dont already have it allso give ya sparkplug leads a good spray with sum wd 40 another trick try wen u finish with the car at the end of the day ie afta work turn off the car , pull choke out and leave it out ready for the morning,,Hi, thanks, butit had a service about a month ago...should I replace the ignition if so what should I upgrade it to to improve things...its a 78 clubby automatic thanksIggynishun plays a part too
If your battery has to turn over a cold engine it has less oomph to spare for making sparks.
A service is a good place to start.
A quick check on the choke is to make sure the cam on the carb connected to the choke cable does actually turn as far as it can when the knob is pulled fully out.
Cold Morning Start
#16
Posted 18 September 2007 - 03:46 PM
#17
Posted 18 September 2007 - 03:47 PM
Chris
#18
Posted 18 September 2007 - 03:52 PM
TAKE the dizzy cap off u should see sum points else u have E I fitted.Sorry to invade your thread, but how do you know if you have electronic ignition? I have a 85 Mayfair would it be fitted as standard?
Chris
#19
Posted 18 September 2007 - 03:53 PM
Chris
Ah that's too technical, nevermind! lol
Cheers jam jam, I'm not having any problems with my ignition or anything yet anyway, you'd know about it if I did
Edited by yorkshirechris, 18 September 2007 - 03:55 PM.
#20
Posted 18 September 2007 - 03:54 PM
Yours wouldn't have it as standard no.Sorry to invade your thread, but how do you know if you have electronic ignition? I have a 85 Mayfair would it be fitted as standard?
Chris
#21
Posted 18 September 2007 - 03:57 PM
hope that helps u out ... wats your new job then if its ok to ask.someone please tell me why my clubby wont start when its cold weather or should Isay colder. need to sort this problem before I hopefully start my new job tried search on here typing in cold startbut couldnt find anything HEEEEEELPPPP!
#22
Posted 18 September 2007 - 04:03 PM
thanks ever so much been told that if I reapply for the laboratory technicians job its 99% sure I will get it have to wait about 10 days or so for reinterview thanks for your help, I will phone a few garages and find out how much to fit an electronic ignition thanks again xhope that helps u out ... wats your new job then if its ok to ask.someone please tell me why my clubby wont start when its cold weather or should Isay colder. need to sort this problem before I hopefully start my new job tried search on here typing in cold startbut couldnt find anything HEEEEEELPPPP!
#23
Posted 18 September 2007 - 04:06 PM
goodluck anyway ,, any time ya stuck give me a shout ya welcom.thanks ever so much been told that if I reapply for the laboratory technicians job its 99% sure I will get it have to wait about 10 days or so for reinterview thanks for your help, I will phone a few garages and find out how much to fit an electronic ignition thanks again xhope that helps u out ... wats your new job then if its ok to ask.someone please tell me why my clubby wont start when its cold weather or should Isay colder. need to sort this problem before I hopefully start my new job tried search on here typing in cold startbut couldnt find anything HEEEEEELPPPP!
#24
Posted 18 September 2007 - 04:42 PM
let me know what they quote u,thanks ever so much been told that if I reapply for the laboratory technicians job its 99% sure I will get it have to wait about 10 days or so for reinterview thanks for your help, I will phone a few garages and find out how much to fit an electronic ignition thanks again xhope that helps u out ... wats your new job then if its ok to ask.someone please tell me why my clubby wont start when its cold weather or should Isay colder. need to sort this problem before I hopefully start my new job tried search on here typing in cold startbut couldnt find anything HEEEEEELPPPP!
#25
Posted 18 September 2007 - 04:52 PM
#26
Posted 19 September 2007 - 09:07 AM
What a pain in the backside, phoned loads of garages over here and they wont do it however finally got through to one but he said not to get it done but to consider something called a ballasted coil etc but still wont do it grrrr ok well got up this morning and she started not first time but it did eventually start...its a newish battery 2 yearsold maybe i should try a new one from halfordslet me know what they quote u,thanks ever so much been told that if I reapply for the laboratory technicians job its 99% sure I will get it have to wait about 10 days or so for reinterview thanks for your help, I will phone a few garages and find out how much to fit an electronic ignition thanks again xhope that helps u out ... wats your new job then if its ok to ask.someone please tell me why my clubby wont start when its cold weather or should Isay colder. need to sort this problem before I hopefully start my new job tried search on here typing in cold startbut couldnt find anything HEEEEEELPPPP!
#27
Posted 19 September 2007 - 09:17 AM
Was this a problem before the service, or did it start just very recently, or quite quickly after the service?
#28
Posted 19 September 2007 - 09:20 AM
not long had the mini, about a month so couldnt really tell you, just phoned up halfords for a price on a new battery and they quoted nearly £80 think I will look around firstHmmm, a ballast system may help, as I believe thats what they were designed for, but plenty of people run without the ballast system and don't have any problems.
#29
Posted 19 September 2007 - 09:46 AM
A mini battery shouldn't be anymore than £50 really, and I'm sure you could pick them up for £30 at some motor factors.
#30
Posted 19 September 2007 - 10:04 AM
