Waxoyl
Posted 19 September 2007 - 07:26 PM
Underside of the car desperately needs waxoyling. Hasn't been done for well over a year.
I have no jacks, nothing to take off the wheels with, or anything.
Am I best going to the local garage and paying for it waxoyling, or am I advised to buy some jacks, tools, waxoyl and a few hours of my time and to do it myself? Bear in mind I have absolutely NO tools, don't think I've got a single jack at all.
If a garage is the best idea, what would be a reasonable price for Bumble to get the wire brush treatment, a coat of hammerite (or not, depends, would you advise this?) and a good dolloping of waxoyl?
I don't want anything else doing except the underside, unless there's anywhere else I'm advised to do... any ideas?
Chris
Posted 19 September 2007 - 08:09 PM
im sure you will be needing the tools again in the future so its not like you'll be wasting money
Posted 19 September 2007 - 08:10 PM
invest in the tools and do it yourself!!!!
Mm, i just don't like the idea of having Bumble on 4 jacks whilst he's being painted. Especially when I've never jacked up a car in my life.
Posted 19 September 2007 - 08:14 PM
if you don't want to do it your self try J C Bates in Brighouse my car always goes there they installed my MED engine and their is always loads of minis in the paint/Work shop
Ignore the Bini on the first page and have a look
Chris
all you need is a jack, 2 axle stands and wheel brace. (paint brush and waxoil of course)
but seriously, if you do it yourself you can get it on nice and thick and you will know that its a proper job
Edited by MiNi FiZ, 19 September 2007 - 08:15 PM.
Posted 19 September 2007 - 08:16 PM
How much is reasonable for a good waxoyling? anyone?
Posted 19 September 2007 - 08:38 PM
A set of ramps will set you back about £30 then all you'd need would be the paint/underseal and some elbow grease.
It can be fun trying to get the car up on the ramps though so be careful.
I'd say it just needs the underside wire brushing, just to get rid of any muck. Then clean up any rust you find and treat it. Then give the whole underside a coat of underseal. Underseal is a bit of a b***h to work with (since its so thick) but it'll do a better job than waxoyl. I reckon wayoyl would just get blasted off pretty easily if you were driving in the wet, where as underseal won't. You'll probably need a litre of underseal at least.
So to do it yourself it'll be £30 for a set of ramps, about £10-£15 for the underseal and a fiver for a couple of wire brushes. So about £50
I say you just go for it and do it yourself. It is quite a big job, it'll take you the best poart of a day to do but it'll be great knowing its been done good and proper.
Good luck
Posted 19 September 2007 - 08:56 PM
What minimadmike said. I've been fettling and fiddling under Huey for several weeks while he's having a new loom made and it's surprising how many people come up and tell me their mini story and even offer to lend me stuff. I swapped my garden shredder for my neighbour's trolley jack and two axle stands. I dug someone else's weed patch in exchange for lessons in using a multimeter and the loan of a grinding wheel and the offer of some welding kit (no, I'm not about to try). The lock-up is very small and I have no power but I use a cycle torch under the car and I find flashlight photos reveal the rusty truth in a pretty vivid way. If we need to turn the car round I get Mrs Teapot to steer and several of us push. There is no substitute for diy and the more mistakes you make the faster you learn (er, I think that's the way it goes). Good luck!I say you just go for it and do it yourself. It is quite a big job, it'll take you the best part of a day to do but it'll be great knowing its been done good and proper.
Posted 19 September 2007 - 09:08 PM
Just dropping it off at the garage is cheating, i say you get your hands dirty!
Posted 19 September 2007 - 09:25 PM
could be safer for you as well.
Posted 19 September 2007 - 09:34 PM
I ended up getting one person on each ramp as i drove up them as they kept moving.
Once its up on them though its fine, put the handbrake on and get some chocks for the back wheels and you'll be fine.
Posted 20 September 2007 - 03:22 PM
Basically to brush off some existing loose waxoyl, and spray on waxoyl to the whole underside of the floors, subframes, under the arches, and under outer-sills, it's £60. He said it's going to take the best part of 2-3 days if I want to chip off all the existing stuff, and give it a coat of hammerite then waxoyl.
There's some welding outstanding under one of the arches which he's quoted £65 to sort out, it's the one where the petrol tank is.
I think for the sake of spendig £125 as opposed to buying loads of stuff myself, locating some ramps/jacks and buying the stuff I might as well just take it to the garage this time.
I know it sounds a bit of a bodge by just spraying over the existing waxoyl but I know for the fact the floors are solid.
£60 sounds fair enough to me, what do you all think?
Posted 20 September 2007 - 04:57 PM
Posted 20 September 2007 - 08:30 PM
and tomdale - yes i'd say start again. You need to waxoyl as much of the underside as possible. I'd use underseal where possible though, waxoyls alrite for the harder to reach areas like inside doors and inside arches. But underseal does a much better job of keeping out water.
Posted 21 September 2007 - 05:53 PM
