- Then jack up the mini
- Remove the wheel
- Take off the old tie bars
- Adjust the new ones to the same length
- Refit new ones
- Put wheel back on
- Mini back on the ground
- ...Then re-tighten tie bar?
Thanks in advance!
Jason
Posted 21 September 2007 - 10:03 AM
Posted 21 September 2007 - 10:10 AM
Posted 21 September 2007 - 10:17 AM
That'd do it. You may not even need to remove the wheel but you might need new, longer, bolts to fix them to the bottom arm if the ends of the new tie rods are thicker. of course, you'll also be fitting new bushes .
If you later adjust their length slacken the nut at the subframe end so the bushes don't get twisted as you turn the rods to adjust the length.
Posted 21 September 2007 - 12:05 PM
Posted 21 September 2007 - 12:08 PM
Ok had a go... thing is cant seem to get the but out... any ideas?
TieBar.gif 243.77K 3 downloads
Posted 21 September 2007 - 12:16 PM
Posted 21 September 2007 - 12:50 PM
Posted 21 September 2007 - 12:51 PM
Posted 21 September 2007 - 12:54 PM
Edited by icklemini, 21 September 2007 - 12:55 PM.
Posted 21 September 2007 - 01:00 PM
Posted 21 September 2007 - 01:24 PM
Posted 21 September 2007 - 02:54 PM
why dont you just turn the hub so the CV is not in the way !!!! Doh!
Posted 21 September 2007 - 03:07 PM
WD40 and heat.
