Splitting The Trumpet From The Cone (rear)
#16
Posted 21 September 2007 - 02:52 PM
#17
Posted 21 September 2007 - 02:56 PM
I'm gonna wait till the old man gets home see what he thinks!
Ha, the impetuousness of youth
You'd only be tackling problems you will have to confront at some point and very possibly avoiding them by early intervention.
#18
Posted 21 September 2007 - 03:01 PM
#19
Posted 21 September 2007 - 06:24 PM
It is perfectly possible (sometimes a little tricky) to remove the radius arms and leave the trumpets and cones in place, but you do need to remove the corner bracket which probably equals seized bolts which equals more work that you won't want to do.
I really would not have got 3 of them out without taking the radius arms off, period. In fact, even when the radius arms were off it was a considerable struggle and they left some of the rubber cone stuck to the subframe.
Good Luck!
#20
Posted 21 September 2007 - 06:44 PM
#21
Posted 21 September 2007 - 07:18 PM
when its undone the radius arm swings lower, it the release the trumpet from the ball coupling on the radius arm, should then "just" have enough space to knock the trimpet out usualy along with the rubber doughnut
doh, sorry read u already done this...ah well
Edited by mini93, 21 September 2007 - 07:19 PM.
#22
Posted 21 September 2007 - 08:04 PM
Thanks for the effort pal!i take it the shock absorbers off?
#23
Posted 22 September 2007 - 11:13 AM
thats how i did it.....along with spraying wd40 betweencone + trumpet n hitting the trumpet towards the knuckle...eventually popped off 3-5min...
#24
Posted 23 September 2007 - 08:06 AM
Thanks for the help guys.
#25
Posted 23 September 2007 - 11:33 AM
My advice to anyone who has 20 year old cones; replace them!
