Clutch Still Stuck >_<
Posted 22 September 2007 - 03:48 PM
Sadly after replacing the slave cylinder my clutch still doesn't want to move The old did look very dodgey tho, and clutch feels smoother but still not disengaging. How can I free it without taking the whole thing apart???
Posted 22 September 2007 - 03:55 PM
Edited by adcyork, 22 September 2007 - 03:58 PM.
Posted 22 September 2007 - 03:58 PM
Posted 22 September 2007 - 04:03 PM
Posted 22 September 2007 - 04:16 PM
The clutch plates can rust together. Warm the engine up to temp. Then take the handbrake off then turn the engine off. Put the car in gear and then start the car with your foot planted down on the clutch pedal.
Then a big violent thing happens and the clutch plates unstick,
Posted 22 September 2007 - 05:44 PM
Posted 22 September 2007 - 06:23 PM
Warm up give it 10-15mins.
To be sure, you can get the car into gear WITHOUT the engine running? Just to make sure. If you can then do my method.
You'll want a clear area to do it in as the car might just start driving. Meaning anything in front of you is what your going to be running into. Just have your foot planted on the clutch when your start. It's a very violent thing to do but it worked for me with no damage to the clutch.
Posted 22 September 2007 - 06:27 PM
Posted 22 September 2007 - 06:30 PM
Same way but stops the car driving off.
Posted 22 September 2007 - 06:34 PM
try the ball at the end of the long arm... maybe v work / broked like mine was ...
the clutch is a bugger,
undo all the top mounts on engine remove horn and things in the way to the left of engine, then the clutch side lower ones, remove rad top mount, bottle jack the sump to tilt the engine and then remove the clutch cover8 or so bolts....takes years!
check for wear, slave cyl push rod, long arm as said before(both ends) release bearing, if all ok then remove the clutch/flywheel setup...flywheel remover and a lil whack and the lot pops off hopefully(fingers crossed)
replace the clutch plate, diaphragm clean everything and put back,
torque the flywheel assembly to 125lb then replace everythin in the reverse order......
simple, last took me bout an hour n half....
Posted 22 September 2007 - 06:52 PM
It's a verto clutch... just replaced the slave cylinder. Can that be adjusted or no? The old one looked buggered even if it did work. The new slave looked to be more "free".Is it a pre-Verto clutch (long clutch arm, slave on top of the trasfer casing)? Have you adjusted it properly?
Is that as effective? I thought it was the sudden jolt to the system that made it unstick, and if the wheels are off the ground then it get that jolt... (??)We did the same but had the front of the car on axle stands, handbrake on.
The haynes manual makes it seem more complex lol. Had you done it before? I don't have anything like a clutch/fly puller. Well maybe somewhere in the garage I'm using but I'd never find it!if it never reads anythin then its the sensor not the thermo, would boil if thermo....
Thanks for the replies
Posted 22 September 2007 - 07:53 PM
Put the car in gear and hold the clutch in then turn the engine over.
DO NOT attempt this without all four wheels on the floor and ample clear space in front of the car!
Posted 23 September 2007 - 09:20 AM
Posted 23 September 2007 - 11:09 AM
