I have a Clubman estate that was running a pre-verto 998 engine with a long clutch arm. The car has now been converted to an A+1275 running a Metro Turbo gearbox. Unfortunately it did not come with the aluminium clutch cover (wok) so I have fitted the long arm cover off the original engine along with a new slave cylinder the same as the original one.
I have bled the system and can see the arm moving significantly but the clutch is not disengaging. Looking in the Haynes, it looks like the verto clutch needs 6.5mm mm clearance throw out clearance, I have this setting and it is moving that much. The Haynes also shows there is a difference between the master cylinder bores, but if the stroke is correct then this does not seem to be the cause. However, I can also see in the Haynes that the release bearings are different between a long arm and short arm assembly. I've also use a pry bar to move the arm a little more than should be required and this makes no difference.
Is the short arm and long arm assembly interchangeable on an A+ Verto engine?
Thanks, Mark
Edited by rallymini, 22 September 2007 - 07:28 PM.
