whats this grinding?
Seconded - Care to share your wisdom? Ive never ground a needle valve in before, i am assuming you mean the needle valve not the float pin valve?
Yeah, the needle valve in the float lid.
Take the float lid off and drift the pin for the float out. Keep the float and pin to one side. Then remove the needle valve. Comes in two parts. A plastic and metal inner with some sprung flat end and a pointy end. Point end goes into the tube nut thingy to make a seal when the float is up.
Remove the tube nut thingy from the lid of the float and mount that in a drill chuck. Then pop some toothpast/valve grinding paste/t-cut into the tube nut thing and then put the other half of the needled valve in. Using some needle nose pliers hold the end of the inner part of the valve and spin the drill so the nut tube bit spins but the other half dosen't. Spin that for a bit, add a little pressure if you like. After a while (long or short as you like, the needle pointy bit is harder than the nut tube bit) take the inner part of the valve out and check it over. Then take the whole lot out and scrub it with some white spirit and make sure it's clean.
Next take a wee fiber washer and put this on the threaded end of the tube nut thing and put the whole lot back together. With the float lid still off the carb flick it upside-down and blow into the fuel inlet and see if there's a leak. If not then put it all back togther.
Cost around £2 to do as you'll prob need a new float gasket and a wee tiny fibre washer. If your pressed for parts the float top gasket can be replace with cereal box card. Only as a temp measure and the wee fiber washer you can probably get for free from a local nut and bolt shop.
