1st Time Spray Job
22 replies to this topic
#1 lrostoke
lrostoke
  • 6,923 posts
Posted 08 October 2007 - 08:52 PM
Hi All
Thought I'd try and get a bit of guidance, seem to be a fair few knowledgable folk on here.
started spraying a mini we are working on, paint we've got is lechler mach 5, BU8 Island Blue
The shop told us to use a 20% mix of thinners.
I've got a 1.2mm nozzle spray gun, and the spec sheet for the paint says 4 atm which is about 58 psi.
I've done all this but I'm struggling to get a wet looking finish, seems to be drying pretty much as it lands, I have experimented with thinner mix and a bit more thinners seems to improve matters..
Any tips would be welcome.
Also when it says 58 psi this is with the trigger pulled, my air pressure is obvioulsy higher without, would this be right, or should it be 58 psi before I pull the trigger.
cheers :kiss:
#2 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 08 October 2007 - 09:11 PM
A 1.2 nozzle is too small really for mac, you will struggle to get a good finish. Ideally you want a 1.4.
I gather you are using hardeners as well? it should be 2/1 with 10 to 20% thinners.
You should have 20 psi when the trigger is depressed for the best finish, thin out the last coat and put it on at about 30 psi.
Pete
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 08 October 2007 - 09:18 PM
Thanks Pete
No shop didn't recommend any harder ?? it seems to go off OK, I think a lot of it is my technique, If I go really slow it does start to look wet and drys pretty quick.
I'll lower the air pressure, sound like I'm at least double what I need to be.
What sort of thinner mix would you say for the final coat...I'm actually at about coat 4 now :lol:
Think I may get a 1.4 nozzle gun as well.
#4 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 08 October 2007 - 09:25 PM
Oops. Mac is HS (high solid), which is only meant to be 2 coats! Although I usually do 3, first one just to cover up the primer.
It'll definitely need hardener, its 2 pack which means 2 components, ie the paint, and the hardener. I don't know how much thinner for the final coat, about 5% more? I tend to just do it by feel.
I suggest you let the coats you have already applied go off for a week, and get yourself a 1.4 gun, apply 2 more coats the way I've suggested and you should be alright :lol:
Pete
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 08 October 2007 - 09:31 PM
okey kokey sounds like a plan :lol:
thats buggered me for this week then :) I've got a week off as well.
I'll have to ask about the hardener .
thanks again :unsure:
Steve
#6 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 08 October 2007 - 09:33 PM
Ah bad timing! :lol: you could always take off the paint with thinners... or maybe not.
#7 lrostoke
lrostoke
  • 6,923 posts
Posted 09 October 2007 - 08:32 AM
Looks like the rains stopped play anyway :unsure: very damp here today, not ideal spraying weather.
Hopefully next post will be pictures of a shiney mini , either that or a bonfire :lol: :)
#8 jayjay66
jayjay66
  • 96 posts
Posted 09 October 2007 - 12:07 PM
Would be interesting to see some pictures!
#9 Bristolboy
Bristolboy
  • 291 posts
Posted 09 October 2007 - 02:20 PM
Seconded.
#10 lrostoke
lrostoke
  • 6,923 posts
Posted 09 October 2007 - 02:48 PM
A few before pictures here, showing progress :lol:
Just hope we sort the paint, we can say we've done it from start to finish then
http://www.orrp.com/...p?topic=34555.0
#11 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 09 October 2007 - 03:54 PM
Didnt read through that, but looked at the pics lol, all i can say is... :lol:
#12 jayjay66
jayjay66
  • 96 posts
Posted 09 October 2007 - 03:58 PM
I hope it all works out!
#13 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 09 October 2007 - 07:50 PM
Wow! impressive work Sir! I must also Add I got the pressure wrong yesterday, you should be spraying at 30 psi or 2 bar. Thats where I got the 2 from... :lol:
#14 lrostoke
lrostoke
  • 6,923 posts
Posted 09 October 2007 - 08:09 PM
I found the spec sheet for the paint
APPLICATION
Spray.
Mixing ratio: by volume and by weight
MAC 5 (MACROFAN lacquer derived from M5000) 1000 parts
00551 (Sopraffino) –00552 (L) LECHLEROID THINNER
or 800-1000 parts
00740 (Speedy) -00741(Medium) THINNER AUTOREFINISHING
Spray viscosity at 20 °C:17- 18” DIN4
Ø Air cap: 1,2 - 1,4 mm
Air pressure: 4 Atm
N. of coats: 2 or 3
Flash-off between coats: 5 min. at 20°C
DRYING TIMES
Air drying at 20°C
Handling : 40-45 min.
Through-drying : 24 h
Low bake at 60°C
15 – 20 min. according to the film thickness
POLISHING
After 8 - 14 h at 20°C according to the film thickness.
I've flatted it all down again, ready to try again :lol: really anoying cause it feels lovely and smooth
#15 lrostoke
lrostoke
  • 6,923 posts
Posted 10 October 2007 - 07:12 PM
I've had it suggested to me, to go over the car with a clear coat, now when the car is wet it does look nice and shiney so is a clear coat likely to give me the shine back, or am I still best trying again with the Mach 5 ??
thanks for all the help
