Edited by scrippo, 01 February 2010 - 06:27 PM.
Project Mayfair
Posted 10 October 2007 - 03:33 PM
Posted 10 October 2007 - 03:50 PM
Posted 10 October 2007 - 05:24 PM
Posted 10 October 2007 - 05:56 PM
wheels are SWEET.
Nice wheels.
Posted 11 October 2007 - 08:27 PM
http://i185.photobuc...metertocome.jpg
This is the dash I'm gonna fit at some point. I've made the centre panel myself with the extra holes for a voltmeter and a rev counter. The car originally had clocks in front of the steering wheel so the wiring loom has to be modified
http://i185.photobuc...ioncontinue.jpg
Engine out, started stripping out all the bits. Don't know if you can see how nasty the bay looks near the brake and clutch cylinders. Here's a picture of it completely stripped and sanded down ready to prime.
http://i185.photobuc...readtoprime.jpg
I'm not after a show finish, just something that will protect from the elements, as I plan to refit soundproofing so it doesn't need to be perfect. Might go for some dynamat type stuff as this will be thinner and look better than the felt stuff.
Bulkhead primed.
http://i185.photobuc...eadytopaint.jpg
I have since cut the front end off and painted the bulkhead. But the plans are to refit front suspension and put it back on it's wheels after the subframe has come back from the powdercoater. Does anyone know if I can powdercoat brake calipers??
Posted 11 October 2007 - 08:46 PM
Cheltenham isnt too far from me.
Keep up the good work.
Posted 11 October 2007 - 08:49 PM
Posted 11 October 2007 - 09:17 PM
Unfortunately its a typical mini, whilst digging around cleaning I decided to remove the front mud flaps and I found this;
Drivers side
http://i185.photobuc...rontarchrot.jpg
Passenger side
This side has rotted through to the A panel as a chunk of filler fell out when I was digging around. Looks like the door hinge panels on both sides are past their best! There are other spots dotted around but it is amazingly solid for a 24 year old car. The floors are mint.
It has some rot in the boot floor and a couple of bodged repairs so I think this'll have to be replaced. Only problem is I can't weld!!! Anyone out there fancy teaching me for a few beers
Oh and I went out and bout myself an angle grinder, and decided to do this
http://i185.photobuc...withgrinder.jpg
I'm gonna go for a carbon fibre bonnet and flip front. First time I used a grinder and I nearly pooed myself.
Posted 11 October 2007 - 09:55 PM
Better to find the rot now rather than after its all ready to go on the road. Make sure you find ALL the rot before welding.
Posted 11 October 2007 - 10:38 PM
To make brackets for the flip front I was thinking of leaving some of the wing metal there, and just attaching the Dzus fasteners to it, rather than having to weld on new metal. However I think both A panels will have to come off to sort the door hinge panels out anyway, so I might as well go with brackets welded to the new A panels.
Thinking of buying a MIG welder, a good book and practising on the remains of my mini's front end. Scared I'll waste loads of money on the welder though! If anyone that can weld can spare some time to show me the ropes, that would be much appreciated!
Posted 11 October 2007 - 10:46 PM
I was told the best way to learn to wed is to write your name in a weld. If you can read it, you can weld. then its just practice and time to get it neater and neater. I know that MiniMag did a series of "how to's" teching you how to weld and the differnt types of weld. Might be worth getting in touch and buying the mags that had it in.
Posted 15 October 2007 - 03:13 PM
I've been reading the minimag series on welding but I think I'd learn a lot more by actually doing it under some supervision of someone who knows what they are doing, then I can know when I'm getting it wrong!
Posted 15 October 2007 - 03:18 PM
I've got a mate who does powdercoating in the Croydon area. PM me if you want anything done and I'll send you his number.
Posted 18 October 2007 - 09:09 PM
I pick up what is apparently a 1275 goldseal engine on Saturday. It's an A-series, not A+, but I think i'll ship it off to get worked on before it goes in!
Posted 22 October 2007 - 07:27 PM
Couldn't pick up my engine on Saturday, might look for an A+ series engine instead as the one I was gonna get was an A series.
Its moving along slowly, just wish I had more time to do stuff.
