Wheel Bearing Change
22 replies to this topic
#1 mini_morley
mini_morley
  • 674 posts
Posted 13 October 2007 - 10:11 PM
Ive done a seach, but couldt find anything.
How hard is it to change the front wheel bearings? '92 City E on Standard 8.4 Setup.
mm
#2 Danny_California
Danny_California
  • 1,263 posts
Posted 13 October 2007 - 10:26 PM
Just had this done on molly by the garage. Apparantly they had a very hard time getting the hubs out, and this guys a proper mechanic, not just a guy who can plug in a lappy. They almost had to take the driveshafts out via the gearbox :( . So yeah, not to easy atall, plus I think you'll need a bearing puller. Cost me £85 inc parts and labor for that and handbrake adjustment.
#3 mini_morley
mini_morley
  • 674 posts
Posted 13 October 2007 - 10:34 PM
Oh, £85 isnt too bad. I was expecting it to be a bit more than that. If its that cheap then i may consider taking it to a garage then...
#4 Tom Booth
Tom Booth
  • 822 posts
  • Local Club: TurboMinis.co.uk
Posted 13 October 2007 - 10:50 PM
Just replaed them on my 91 city :ph34r:
There a doddle. Just make sure you have a good ball joint seperator, and something suitable to drift the outer races of the earings from the hubs :( Remember to torque the castle nut up properly too!
#5 Ethel
  • 26,107 posts
Posted 13 October 2007 - 11:09 PM
Depends,
It doesn't have to be a problem, I'd have a go if it doesn't want to play just pop it back together 'n call in the A team :(
#6 alexcrosse
alexcrosse
  • 3,786 posts
Posted 13 October 2007 - 11:12 PM
not hard, just keep wacking those ball joints and as soon as ur hubs free its easy.
#7 jayare
jayare
  • 2,093 posts
Posted 14 October 2007 - 12:13 AM
Worst part is getting the hub nut undone - that can be a right bar steward! Take the wheel off, remove the split pin then put the wheel back on (if it's a steel one - use the spare if you've got alloys - the hole in the middle is bigger to get the socket through) put the car on the ground, in gear and handbrake on, then use a long breaker bar to crack the nut if need be. Turn the steering slightly to avoid mashing your wing or wheelarches. Other than that you only need a good ball joint splitter - scissor type rather than the bludgeoning fork one - and a torque wrench to make sure of the correct torques on reassembly. When you drift the new bearing races in, use the old one ad a drift rather than hammering on the new bearing.
JR
#8 JoeMcb
JoeMcb
  • 165 posts
Posted 14 October 2007 - 09:43 AM
glad this topic got made - answers my questions 2!
#9 Bevan
Bevan
  • 736 posts
  • Local Club: On the search!
Posted 14 October 2007 - 11:45 AM
I had to replace my wheel bearings, paid £40 for the set, ended finding out i need to replace new disc, pads, one caliper was seized up, but the bearings where the easy part, gave the hub to a mate in a garage to use a compressor and he never needed to use it.
#10 mini_morley
mini_morley
  • 674 posts
Posted 14 October 2007 - 11:59 AM
So what exactly will I need?
Ball joint splitter,
Torque wrench,
New bearings
Will i need new ball joints aswell? Mine havnt been on that long (about 4 months)
#11 Ethel
  • 26,107 posts
Posted 14 October 2007 - 12:17 PM
Torque wrench,
New bearings
1 5/16" socket, you won't need new balls but you might hole the rubbers - you can buy them for pence
#12 Ollie180
Ollie180
  • 2,781 posts
  • Local Club: Sasmog.co.uk
Posted 14 October 2007 - 12:28 PM
they easy! did mine when i first got my car, now need to do one again :( bloody 13inch rims :ph34r:
#13 Don't Panic
Don't Panic
  • 642 posts
Posted 14 October 2007 - 04:42 PM
Ollie, just out of curitosity how long did your bearings last with 13's?
#14 minivanman
minivanman
  • 3,454 posts
Posted 14 October 2007 - 08:47 PM
This is what you need to do the hub nut:
That bar locks it against the floor, so you can undo it without having an assistant standing on the brakes. Very very simple to make as well.
#15 Ollie180
Ollie180
  • 2,781 posts
Posted 14 October 2007 - 09:02 PM
bout 9 /10 mouths but i do push it round corners alot :-
