Calculating Gear Ratios?
25 replies to this topic
#16 Ethel
  • 26,028 posts
Posted 23 October 2007 - 10:36 AM
not calling 1st 3rd 'n 3rd 1st are you Jammy - 3rd 'n 4th are next to each other on the shafts.
#17 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 23 October 2007 - 10:37 AM
You're going to have to put a pic up of the parts.... was the set removed from a gearbox or is it just a 'collection' of gears ?
#18 Ethel
  • 26,028 posts
Posted 23 October 2007 - 10:54 AM
Just occurred to me that 1st, the gear with the most torque, is closest to the final drive - clever these engineer types aren't they? :thumbsup:
#19 Jammy
Jammy
  • 25,397 posts
Posted 23 October 2007 - 10:58 AM
I'm going to have a recount at lunch, I've obviously wrote them down in the wrong order!
#20 Jammy
Jammy
  • 25,397 posts
Posted 23 October 2007 - 12:04 PM
Right, laygear is 15, 19, 23, 25. Gears as follows:
1st - 31
2nd - 25
3rd - 22
4th (1st motion) - 19
Definitely 31 teeth on 1st gear. Will work out ratios when I get back to work, but I've just worked out 1st as being 2.7192.
#21 Jake Blues
Jake Blues
    TMF Moderator
  • 2,955 posts
  • Local Club: Central Minis
Posted 23 October 2007 - 12:47 PM
Long since gone...
Now on here... http://www.guess-wor...ox/index_R.html
Ta!
#22 Jammy
Jammy
  • 25,397 posts
Posted 23 October 2007 - 01:07 PM
Ok, calculated the ratios as follows:
1st - 2.719
2nd - 1.73
3rd - 1.25
4th - 1
It seems I do have the ST Abingdon set, but with a standard 1st gear. next job is to bolt it all together and see if it actually works, if not one ST 1st gear to be bought!
#23 andydlc
andydlc
  • 77 posts
  • Local Club: JMC&LCC
Posted 05 November 2007 - 11:42 PM
Help!!!
I have worked out the ratios of the dog box,
1st gear =0.2734
2nd gear=0.4355
3rd gear=0.5985
4th gear =1
Layshaft - 15, 19, 21 & 23
Gearteeth - 31,27,24 & 23
Pinion gear = 13
13/23 = 0.5652 x
15/31 = 0.4838
______________
0.2734
13/21 =0.6190 x
19/27 =0.7037
______________
0.4355
13/19 =0.684 x
21/24 =0.875
______________
0.5985
Where do i go from here???
How do I figure out what gearkit i have??
Hope someone can help!
Andy
#24 Jammy
Jammy
  • 25,397 posts
Posted 06 November 2007 - 09:00 AM
The calculation I use is the one from Guessworks FAQ:
1st motion teeth	  Leygear teeth for gear
ratio  =   -------------------  *  --------------------------
				Laygear teeth				Gear teeth
Since your 1st motion gear and corresponding laygear have the same number of teeth the first half of the calculation is always going to be 1.
So 1st gear is 1 x 15/31 = 0.48387. You then divide 1 by this number (explained in the FAQ) to give you a ratio of 2.06667.
Using the same calculation I got the following ratios:
1st = 2.06667.
2nd = 1.42105
3rd = 1.142857
4th = 1
#25 andydlc
andydlc
  • 77 posts
Posted 06 November 2007 - 05:51 PM
Thanks Jammy_basturd!
Thats some weird ratios then!!
#26 Jammy
Jammy
  • 25,397 posts
Posted 06 November 2007 - 06:47 PM
Don't thank me yet. It took me two pages just to count my teeth correctly! :lol:
