Bmw K1100 Head Conversion
40 replies to this topic
#1 scrippo
scrippo
  • 535 posts
Posted 05 November 2007 - 12:11 PM
Hi all,
After looking all over the different forums I can't find an answer to my question.
I've discovered my dad has a spare BMW K1100 head (he actually has a spare for a bike for a change, not a mini!!) I'm currently 'in negotiation' to get this off him, so I can build an engine for my mini. I'm not yet sure if it's an 8v head or a 16v.
My questions are;
What parts do I need from the bike aside from the head?
Can I fit the head on any bore from the 1275 up (ie will 1293, 1310, 1340, 1380 bores work?)
I assume the head replaces the need for a cam in the A series block, is this correct?
I don't particularly want to munch gearboxes, realistically what spec of gearbox can I use? Will a rebuilt 'box with s/c gears and comp diff pin handle the power?
My plan would be to get all the machining/fabricating done by people who know what they are doing, then buy a kit from either MSPD or SC so I can bolt it together myself. I haven't got a massive budget, hence only going for this option if I can get the head cheap from my dad!
John
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 05 November 2007 - 12:28 PM
there are a few topics about this in the projects section
i know scurvy dog is doing this conversion his self so start there
#3 Sam Walters
Sam Walters
  • 2,765 posts
Posted 05 November 2007 - 12:31 PM
it will fit any engine from 1275 up however the cam needs to stay in the block as it drives the oil pump iirc. some stright cut drop gears and a 4 pin diff should be okay, however keep below 140bhp with it and youll be okay, the clutch will need to be changed maybe a double grey.
stright cut drop gears are a must to be honest, however in the gearbox i belive stright cut gears to be just as strong as helical cut gears.
#4 scrippo
scrippo
  • 535 posts
Posted 05 November 2007 - 01:30 PM
Keep below 140 bhp! Like the sound of that!!!!! I think around the 110bhp mark will suit me fine. I had a 205 gti for a while that would be lucky to be running that and it was great fun, so a mini should be amazing with that sort of power!
Does anyone know what parts are essential off the bike?
#5 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 05 November 2007 - 05:25 PM
could always get an electronic oil pump :thumbsup: then u wouldnt need the cam in the block
oh and as for the kit JohnK at specilist components is the guy to talk to, if you buy the build guide for £20 tells exactly whats needs to be done! an absolutly exelent book
#6 Jammy
Jammy
  • 25,397 posts
Posted 05 November 2007 - 05:40 PM
An Orange should be fine for 110bhp, a grey for 150bhp+ really. Saying that clutches don't see bhp, they see torque...
You don't need straight cut gears for the conversion.
#7 scrippo
scrippo
  • 535 posts
Posted 05 November 2007 - 07:18 PM
Might go down the electric oil pump route. Can't see the point of keeping the cam in there if it's not doing anything other than pwer the oil pump.
Was thinking about buying that guide book, I think I'll wait until my dad actually gives in and lets me buy the head!!
The results from this conversion look pretty impressive. 107 bhp from an engine that is basically a standard block.
#8 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 05 November 2007 - 07:49 PM
U will need to keep the cam in place unless u are running a dizzy less ignition system
#9 mini93
mini93
  • 8,615 posts
Posted 05 November 2007 - 08:08 PM
most people do go for fuel injection so it seems sorry i seemed to take that for granted, mini kel is right yourl need electric fuel pump and distributorless ignition system. i think then you can also do away with the timing gear as well obviously it wont be driving anything
then go electronic water pump, electronic radiator fan, do away with the interior heater and get heated front screen
and last but not least a battery which will be able to cope, the redtop motorsport batterys i believe are high current for there size...ooh these are same as my plans lol
#10 scrippo
scrippo
  • 535 posts
Posted 05 November 2007 - 09:50 PM
Yeah I like the look of the Megajolt system with EDIS as it'll be much more reliable than the old points/dizzy combo, so that won't be a problem. Is it the fuel pump or the oil pump that I'll need to replace with electric (or both?).
Do I need to run fuel injection with that head?
#11 ginigwunkle
ginigwunkle
  • 2,018 posts
  • Local Club: sheffield mini club
Posted 05 November 2007 - 09:56 PM
itll be both as ther all driven by the cam!
you can use bike carbs, depends which bike it came off as to which bits will be included....
#12 mini93
mini93
  • 8,615 posts
Posted 05 November 2007 - 10:01 PM
the k1100 was one of the 1st bikes to utlise fuel injection so if your planning to run carburettor a custom manifold will be needed
#13 matty...
matty...
  • 605 posts
  • Local Club: Turbominis
Posted 05 November 2007 - 10:14 PM
Has anyone got any links to these projects...cant' seem to find them anywhere? :D
Would be good to see how others are solving the endless problems they encouter..lol
#14 mini93
mini93
  • 8,615 posts
Posted 05 November 2007 - 10:16 PM
matty, not really started anything yet, but mines linked in my siggy, got some help from ya lot over on turbo mini's
#15 matty...
matty...
  • 605 posts
Posted 05 November 2007 - 10:28 PM
Ah looks like you've made a start. I see your blowing it too...good work! :D
