Converting From Centre Speedo To 3 Clock
#16
Posted 06 November 2007 - 08:16 PM
It's no walk in the park, that's for sure!
#17
Posted 06 November 2007 - 08:47 PM
Thanks For the help though
Ali
#18
Posted 06 November 2007 - 10:40 PM
Driver side clocks. I've seen it done on a blue de-seamed mini and though it looked very nice indeed.
Hold on, let me find the issue.
Ah, found it.
[attachment=43268:P1010659.JPG]
speedo in front of clocks, might well will need a longer speedo cable.
#19
Posted 07 November 2007 - 10:47 AM
There is one option you haven't thought of.
Ah, found it.
Thats a cool idea, may consider that when designing my dashboard.
Ali
#20
Posted 07 November 2007 - 11:07 AM
I've also just done the reverse on a project mini where Ive converted that one from triple clocks to center speedo plus voltmeter and water temp...this time I cut off the original multiplug off the triple clocks and used bullet connectors to wire it to the correct wires on the central speedo...luckily the central speed came with all the bulb holders etc in place.
#21
Posted 07 November 2007 - 11:15 AM
The wiring of the triple clocks isn't that difficult, the set I brought came without the multiplug, so I just followed each circuit on the clocks from the plug till I found where it went on the clock, I then soldered individual wires to each circuit and then using a large choc block connector wired these to the corrisponding wires on the original loom.
Hiya Steve!
so you still used the multiplug, but spliced the appropriate wires into it, yes? My problem is that if I produce a custom loom for someone I would prefer to have original connectors properly crimped as new, but the multiplugs aren't available...
#22
Posted 07 November 2007 - 11:57 AM
On the 3 clock to center clock conversion, I cut off the multiplug on the original 3 clock loom...and put a female bullet connect on each wire. I suppose in hindsite splicing into the loom rather than cutting the plug off would have been better incase somebody wants to revert back to a 3 clock set in the future.
Then on the center clock I put a male bullet connector on each wire on there... most of the wiring seems to be the same colour code as well .
Helped that the centre clock set had all the bulb holders in place still. Only aditional wires I've had to add was a feed to the voltmeter.
On my mini where I converted from center to 3 clock I had to solder individual wires to the actual printed circuit on the back of the 3 clock setup, I then used these wires to connect to the original centre clock loom using a choc block connector.
Pity I didn't know we were doing the project mini when I did my 3 clock set up, I could have just swapped plugs
Edited by lrostoke, 07 November 2007 - 12:00 PM.
#23
Posted 07 November 2007 - 12:16 PM
