Linux Help.. (msn On Ubuntu)
Timtom
, Nov 09 2007 05:23 PM
13 replies to this topic
Posted 09 November 2007 - 05:23 PM
Hello!.
Atm.. Im running Ubuntu (feisty fawn) on my computer, I want to run MSN on here.. At the moment I'm using aMSN but it really really sucks. And using Wine im sure I can run real MSN but the older versions try to get you to update(tried it before on a different computer) But how would i get them running? The newest version as possible..
Understand?
Thanks!.
Understand?
Thanks!.
Posted 09 November 2007 - 05:24 PM
Understand?
no
Posted 09 November 2007 - 05:28 PM
Posted 09 November 2007 - 05:51 PM
yep i'm a linux user i'm runing gutsy kubuntu KDE
David.
David.
Posted 09 November 2007 - 05:58 PM
I would recommend pidgen (was called gaim) as a decent alternative.
Have you got Wine installed and running ok? What errors are you getting? It 'should' allow the latest MSN.
This link might help http://sidenet.ddo.j...ips/config.html
Posted 09 November 2007 - 06:02 PM
Gaim's not too bad... Just a bit too simple.. (not enough features)
And.. I downloaded it (proper msn).. But it won't install.. I'll try again
Posted 09 November 2007 - 06:20 PM
Could always use Windows?!
Posted 09 November 2007 - 06:22 PM
Well ive tried installing msn.. It starts the setup.. But spazzes up..
Posted 09 November 2007 - 06:36 PM
Error codes? When does it spaz up?
Posted 09 November 2007 - 06:38 PM
Its all fine.. (Windows live setup) until the end it tells you its not installed it.. And the error is 1603?
Posted 09 November 2007 - 06:44 PM
Well according to the WINE forum you can't run the latest MSN. Although it does say MSN 7.0 works.
http://appdb.winehq....?...on&iId=3179
Why do you NEED msn on linux the very reason to switch to linux is to get away from Microsoft
Posted 09 November 2007 - 11:13 PM
Can't really help out on this topic - I don't use MSN very often, and defo not on Linux.
Got to ask though, have you looked at the other Linux alternatives, there are tons out there. Some good, some bad.
You could do what I plan to do for my next computer - Linux as the installed OS, with windblows running in VM - best of both worlds. The VM install should be more or less the same as running windows as intended, but you only call it up when you *NEED* a windows specific program, and even if (read when) windows crashes, the computer will carry on as normal, and you will only need to restart the VM windows (and you can modify windows to boot damn quickly too).
If I can work the bugs out, I plan to use this exact setup for running windows based games from within Linux, rather than dual boot.
SS
SS
Posted 19 January 2008 - 11:48 PM
I use pidgin! My other half is the comp wizard....did you get this sorted?
Posted 19 January 2008 - 11:55 PM
Aha. After using aMSN for a while.. (it annoys me so much though!!.. Its all the 'joins conversation' rubbish!!)
I tried Mercury Messenger again.. After it not working a while ago.. And it magically worked..
So I'm using that
Thanks anyway guys!!
So I'm using that
