MOT time !! :-(
Posted 03 March 2005 - 12:54 PM
Posted 03 March 2005 - 01:26 PM
Posted 03 March 2005 - 01:48 PM
No. plate light out,
o/s & n/s track rod ends,
o/s & n/s front subrame mounts broken away!
Excessive play in n/s/f wheel bearings,
o/s lower ball joint worn,
o/s/r footbrake inopperative,
exhaust emissions high.
Plenty to keep me busy this weekend in the snow (
Anyone else out there with a modified MPI who has had trouble passing the emissions test?
Posted 03 March 2005 - 01:53 PM
Hope you get it all sorted.
Posted 03 March 2005 - 02:59 PM
Posted 03 March 2005 - 03:08 PM
Posted 03 March 2005 - 03:14 PM
Posted 03 March 2005 - 04:14 PM
Ball joints- mine fail on every year, 1 side bearings were gone aswel.
subframe mounts sound a bit daunting tho!!!
Posted 03 March 2005 - 04:16 PM
Posted 03 March 2005 - 05:35 PM
Do what I do, ask them to tweak it in, oh, hang on, no carb...I've got a free retest if I take it back within two weeks, which is why I didn't bother to go over it before I took it in. It's a bit cold out and I'm very nesh! Still, not too bad. I was aware of some of the stuff so I'd already ordered the parts beforehand. It's the emissions that I'm a bit worried about. It's got quite a lumpy idle and is pretty rough below 1500 rpm due to the cam and big valve head. I'm not sure if I can do anything about it. Interestingly, the number plate light is working!? I guess it must be an intermitant fault?
Dunno if they can tweak it in with an MPi....
Posted 03 March 2005 - 06:51 PM
My '84 car sailed through first time again last week, as ever!
Posted 03 March 2005 - 07:14 PM
Posted 03 March 2005 - 08:50 PM
Posted 03 March 2005 - 10:29 PM
The engine is quite heavily modified; 1380, big vavle head, high lift rocker, longer duration cam, etc. The fuel pressure regulator has been uprated to a 3.5 bar item to provide the necessary additional fueling at high revs, the trouble is, it causes very rich running at idle. In fact, when it has been idling for a while, such as in traffic, it starts to choke itself on unburnt fuel. I usually have to blip the throttle a couple of times before pulling away again. I have an Emerald ECU which I am in the process of wiring up to the car, but it's not ready yet. I suppose if all else fails I will have to hurry and get it finished, but then it will need mapping, or I could become good friends with an MOT tester I haven't had a chance to familairise myself with the injection models yet, but there must be a way of adjusting the idle co, surely? I have a lambda reading of 5042.538, about 5042 times more than what it should be, you won't be surprised to learn that the fuel consumption is worse than my Volvo T4 ! OH my poor baby! I've got another 11 days left on the current MOT certificate, and I don't use it everyday at the moment, until I sell the T4, so I've got time to sort it out. I now see why nobody bothers to tune the injection models. My GT is a lot easier to deal with, a quick twiddle with a screwdriver and it sails through the emissions test. The old 'uns are the best.
Posted 04 March 2005 - 10:23 AM
Recognition at lastA quick twiddle with a screwdriver and he sails through the emissions test. The old 'uns are the best.
