Rollcage And Seats
Posted 12 November 2007 - 01:38 PM
I would really still like to use my back seats so do I need to fit bucket seats or could I fit a cage with cobra Le Mans seats.
I was also looking at these harnesses securon Harness Pn. 700 - Three point Harness with Retractor . This can be disconnected so I could use the back seats occasionally and leave in the normal belts.
How safe are cages. Will they help in an accident or make it worse.
Any help appreciated
Zeroasylum
Posted 12 November 2007 - 02:01 PM
If your fitting a roll cage, then technically you should use bucket seats to stop parts of your flailing about in an accident, hitting the cage and breaking. So if you do fit bucket seats then I refer you to the point above.
Have a search for rollcage/ roll cage, the views on whether they are safe in an accident have been discussed many times.
If you do fit a cage then you must fit proper roll cage padding.
Posted 12 November 2007 - 02:04 PM
i'd hate to hear of another mini accident where the drive bounced his head off of the top rail
Posted 12 November 2007 - 02:19 PM
Cant you just use a normal seat belt if you want to? (with buckets)
Just asking is all.
Posted 12 November 2007 - 02:25 PM
If the belt or harness isn't tight to your body, and your body is allowed to travelled forward before meeting the belt/harness in an accident then you can suffer quite badly with damaged ligaments, broken shoulders, very bad whiplash, etc. That goes for keeping a harness loose so you can reach buttons on the dash too!!!
Posted 12 November 2007 - 02:33 PM
Cheers Jammy
Posted 12 November 2007 - 02:40 PM
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/grin.gif)
Posted 12 November 2007 - 02:59 PM
not as safe but it keeps most of the metal bars away from your body
Posted 12 November 2007 - 05:06 PM
Posted 12 November 2007 - 05:13 PM
It's Illegal to have rear seat passengers in a car with a roll cage.
It is?... whoops....
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/dontgetit.gif)
Edited by minimadmike, 12 November 2007 - 05:13 PM.
Posted 12 November 2007 - 05:17 PM
Posted 12 November 2007 - 05:19 PM
Posted 12 November 2007 - 05:56 PM
If it is illegal I can see why. But if the roll cage is padded well and the passenger has there seatbelt adjusted properly then its not so bad.
true but that doesnt make it not illegal
![=]](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/tongue.png)
Posted 12 November 2007 - 06:40 PM
Posted 12 November 2007 - 06:53 PM
