hi everyone
I went out to my mini the other morning and the battery was flat even though the night before it was fine. ive tested the battery and alternator and there fine, but my battery is still losing charge
does anyone have any ideas
cheers andy
Battery Losing Charge
cripit
, Nov 13 2007 07:34 PM
11 replies to this topic
Posted 13 November 2007 - 07:34 PM
Posted 13 November 2007 - 07:50 PM
charge the battery and leave it disconnected for a few days then try it again
if its flat its got to be the battery
if it has power and starts your mini it must be the mini's wiring
if it's the mini wiring get back to me and i can talk you through some tests
Posted 13 November 2007 - 08:37 PM
Check engine earth strap is in good condition, and clean around where it bolts up. This could prevent efficient charging. Worth a try!
Posted 13 November 2007 - 09:03 PM
i will try the earth strap tomorrow but the battery is brand new and is the uprated one
cheers
cheers
Posted 13 November 2007 - 09:04 PM
cheers
cheers
cheers
cheers
Posted 13 November 2007 - 10:42 PM
Hi
Be gentle with me......
Why has the positive got a screw isn't it ,is it a special battery or just a mini battery?
cripit the battery is draining , do what they say....
Posted 14 November 2007 - 07:21 AM
do you mean the screw in the top of the terminal ?
it stops the battery terminal jumping off the battery
Posted 14 November 2007 - 07:35 AM
could have a short somewhere, could also be a faulty battery
Posted 14 November 2007 - 10:54 AM
it got water in it??
Posted 14 November 2007 - 06:06 PM
the battery hasnt got a screw in the top of the terminal and the battery was fine this morning and i havernt done anything to it yet yeah the water is fine and its the second battery ive put on it to be sure its not that
Posted 14 November 2007 - 07:00 PM
the screw was a separate question from someone high jacking your topic
